Level control module bad? Code 00775
2003 Audi Allroad. Getting error code
First thought the sensor itself (corroded, wires, sensor internals), but reading the Rosstech description, could it be the module?
Is there a way to test the module (VAGcom or else)?
00775 - Level Control System Sensor; Rear Right (G77)
57-00 - Electric Circuit Failure
00775 - Level Control System Sensor; Rear Right (G77): Implausible Signal
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Communication Problem between Level Control Module (J197) and Headlight Aim Control Module
Wiring/Connectors from/to Level Control Module (J197) faulty
Possible Solutions
Check Communication Problem between Level Control Module (J197) and Headlight Aim Control Module
Check Wiring/Connectors from/to Level Control Module (J197)
Possible Symptoms
Possible Causes
Possible Solutions
Possible Symptoms
Possible Causes
Possible Solutions
Possible Symptoms
Possible Causes
Possible Solutions
other thing to check:
their is a joint connector to that sensor under the rear bench seat, make sure it is not corroded/damaged
you could swap the sensors from another corner to see if the fault code moves corner
also i have read a rear right level sensor can be a red herring for a fault in another module, any other faults stored elsewhere, ABS or other?
regards
Andy
Banned
'65535 - Internal Control Module Memory Error' is the failed module code
check the connections and wiring to the level sensors, never hurts to put some dielectric grease in the connectors to help water proof them
mikef
Audi allroad
10-25-2005 01:33 PM
malcho
05-20-2003 07:46 AM
