Audi Allroad Suspension Woes
I've bought a 2002 Audi Allroad with non working suspension on its bump stops (got it very cheap)
We have read the following with a VagCom can you point to what is wrong
Address 34:Level Control Labels: 4Z7-907-553.lbl
Part No. 4Z7 907 553 E
Component: - 2C1A1 D040
Coding: 25500
Shop *: WSC 09999
VCID: 479B01636541D3261AD-5178
8 Faults Found:
00807 - Suspension Strut Valve; Rear Left (N150)
31-00 - Open or Short to Ground
00808 - Suspension Strut Valve; Rear Right (N151)
01316 - ABS Control Module
79-00 - Please Check Fault Codes
00805 - Suspension Strut Valve; Left Front (N148))
00806 - Suspension Strut Valve; Right Front (N149)
01397 - Venting Solenoid fro Level Control (N111)
Please Check Fault codes
01399 - Relay for Level-Control Compressor (J403)
31-00 Open or Short to Ground
Coding: 25500
Shop *: WSC 09999
8 Faults Found:
Coding: 25500
Shop *: WSC 09999
8 Faults Found:
Coding: 25500
Shop *: WSC 09999
8 Faults Found:
clear all these faults and see what faults come back?
note: also read and clear ABS faults, let us know what faults come back,
if they all come back check fuse posuition 5, 6 & 17 and make sure it has a suspension ECU fitted in the boot!!
regards
Andy
This suggests everything is unplugged,
regards
Andy
regards
Andy
Regards Steve
nfocuz
Audi allroad
02-27-2008 05:15 AM
