Battery drain issue update (additional help needed)
Old 05-18-2016, 09:55 AM
  #31
vtraudt's Avatar
Originally Posted by jaendor9
hi
did you find out what 2 do with the car? i have the same problem with mine. battery drain. 0,69amp. without cd/radio fuse 0,31amp and if i also remove navigation fuse im down on 0,03amp drain.
after 2-3 days i have starting trouble. how can i fix the problem?
have orginal rns navigation. allroad c5 2003 model. i recently put in a pioneer 2din player, but i had the same problem before i put the new player in the car.
In my case: I had a bad door microswitch. The doors all locked just fine, but the microswitch did NOT inform the ECU that door is locked. So the ECU (or othe rmodule?) did NOT go into 'hibernation' or sleep mode, continuing to draw high.
I fixed the door switch and the draw disappeared.
Old 05-18-2016, 10:10 AM
  #32
jaendor9's Avatar
Ok.
But how did you know that one microswitch was bad? See it on a vagcom? I think the switch 2 the backdoor is bad, had a problem with it knowing the back was closed
The_Mizarc
03-16-2015 08:09 PM
jim-bo
Audi allroad
01-30-2013 03:07 PM
deba0016
Audi allroad
03-28-2010 12:39 PM
ErikS4
07-07-2007 05:28 PM
TheObiJuan
03-13-2004 07:47 PM
Quick Reply: Battery drain issue update (additional help needed)
