Brake caliper torque spec needed
Hello
What are the torque specs for the front calipers? All 6 bolts:
2 bolts that attach caliper to wheel hub, take 21mm 13/16 wrench
4 bolts that screw caliper halves together, take hex key.
And, should I put a dab of loctite on some or all? (Didn't have any when taken apart.)
Thanks Art
2004 allroad 2.7T
Thanks Art
2004 allroad 2.7T
'2 bolts that attach caliper to wheel hub, take 21mm 13/16 wrench' - 200 Nm or 148 ft-lb
the other bolts you are talking about I assume it's the 'brake caliper to pad carrier'(in the service manual)- that would be 25 Nm or 18 ft-lb
Edit: Torx scres not hex screws.
am_ver
09-21-2009 10:02 PM
blackfnTTruck
13
11-17-2007 08:09 AM
CraigB
02-06-2000 08:02 PM
