cigarette lighters don't work.
I have a 2000 All-Road Quattro in great shape but none of the cigarette lighters work. The red lights around the plugs work but when you push them in, NOTHING! I tried the lighters in my other car and they worked fine. Any ideas?
Thanks
Ron
Thanks
Ron
It is most likely a fuse. Check the manual and it will tell you what fuse to check. I believe both the on in the dash and the one in the back seat console share the same fuse. The one in the rear cargo area is on a different one.
-Mike
-Mike
Most likely fuses, or short to ground
Steps:
-run VAG to confirm codes, diagnosis, and repair instructions
if fuses
-open drivers side door
-remove fuse box cover
-cover contains detail of fuse locations
-use a multi meter or fuse detector to confirm VAG codes before you replace fuse
Steps:
if fuses
Same happened to me and it was the fuse. And yes, they do share the same fuse. In my case, a peeny fell into the lighter in the front. I keep coins in the ashtray and one spilled into the hole while the lighter was out.
the_duke
09-10-2015 09:02 AM
stormchaser1967
09-02-2015 09:26 AM
