Cold Weather Suspension Issues
#24
moisture
Most of the moisture trapped in the Air Dryer (Integrated in the Compressor) And some in the valves block. The compressor can be dismantled and dry the air dryer. The valves block also can be dried, You need special tools and understanding the electrical system to do it. If you have no more air leaks It is enough to dries the compressor in time eventually go dry. (Maybe will need more time to dry the compressor)
#25
Great description and diagram.
Should you have really excessive moisture and feel the need there is a supplier on eBay that sells a compressor rebuild kit with replacement filters and drying media as well as the piston ring, new bolts and the wiring ties called LandyAir out of the UK.
I used a kit from Bagpipping Andy and it worked like a charm and was about $30 cheaper and arrived in a few days (using his North American supplier) vs the 1-2 weeks to get the other kit from Britain.
I was able to get rid of the majority of the moisture by clearing the lines and wiping the compressor bore dry prior to reassembly. Also as the temperature was about -10 degrees I decided to fix the absolute minimum needed to get back on the road.
#26
#27
Air system
The valve block contains 5 air valves and pressure gauge. And it receives instructions from the height level control computer. The valves work open\ Close.
#29
valve block drying
Yes, You disconnect all hoses And the electric plug. Connect an external air pressure source, Connect an external plug (From e Bay) With DC 7 V You open each valve in turn. The plan of the electrical plug Exists
MR711
01-23-2006 08:35 AM
Wowdi
19
02-21-2004 06:53 AM
