Cracked Upper Pan? - AudiWorld Forums
Cracked Upper Pan?
Old 02-17-2017, 09:26 AM   #1
mattwelds's Avatar
Default Cracked Upper Pan?
Could this be considered a cracked upper oil pan? Replacement necessary? Discovered this on my way to the rear main seal while replacing clutch. (pics rotated incorrectly, sorry)
thanks
Cracked Upper Pan?-20170217_091817.jpg   Cracked Upper Pan?-20170217_091918.jpg
mattwelds is offline   Reply With Quote
Old 02-17-2017, 12:27 PM   #2
mattwelds's Avatar
It looks kind of like hairline spidering as if the motor was dropped or took one monster of a speedbump. I have no PO history or maintenance records. The PO didn't even know the owners manual was under the steering wheel. It's entirely possible the motor had been out of the chassis before as it appears as though an enthusiast owned it at one point. stoptech BBK, h-sport sway bars f/r, AWE transmission cross brace etc. Anyone seen this condition on an aluminum upper pan before? Does the C5 allroad forum get many replies these days? Is it against the rules to also post in the 2.7t and A6 forums? I'm already over my time limit for this project...
any input would really help me out here
thanks
Old 02-17-2017, 05:28 PM   #3
Is it leaking noticeably? If yes than replace it. If no than don"t **** with it.
Always good words to live by.
4xaudi is offline   Reply With Quote
Old 02-17-2017, 09:29 PM   #4
mattwelds's Avatar
it's hard to tell. the clutch slave recently popped it's cap and puked it's fluid inside the bellhousing. the entire outside of the pan and inside of splash shields were also caked with oil and road grime. but your suggestion has been duely noted. I've cleaned a bunch of gunk out of the PCV system and I can always just do the valve cover and cam seals with the motor in the car so, back in it goes.
thanks 4xaudi. not sure if that was what i needed to hear but it was absolutely what I wanted to hear. Ive never owned a vehicle that was such a pleasure to drive while being such a PITA to work on.
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
