Problem with 402 module
Old 02-05-2010, 10:56 AM
Audiholio's Avatar
Default Problem with 402 module
I am unable to login to control modules for level control...I get following message in Vag-Com:
"login lost due to dropped session"....everthing else is working fine.
What is causing it ?
Thank you !
Old 02-05-2010, 12:07 PM
paulroad's Avatar
do you have a screen saver set on your laptop? I have found when it kicks in the session will fail.
Old 02-08-2010, 11:31 AM
Audiholio's Avatar
No screen saver.
Old 02-08-2010, 11:35 AM
Audiholio's Avatar
Anybody help ?
Old 02-08-2010, 05:27 PM
grat's Avatar
any chance you're using a 9pin serial vagcom with a usb-serial converter? I had similar problems with mine before upgrading to the usb version.
fj..
Old 02-09-2010, 12:20 PM
Audiholio's Avatar
I am using USB version of the cable. It happens on either version 3x and 4x. Dont know what can cause it
Old 02-09-2010, 07:40 PM
grat's Avatar
Have you posted this on the vag-com list? It sounds more of a data fault and/or connection problem rather than a specific programming problem. I've got the Ross-Tech Hex-usb and have done 4 or 5 402 sessions without problems. Only other thing I can suggest; is to see if there is someone else local to you with another vag-com, to see if they get the same error on your car to see if you can narrow it to the unit or the car.
fj..
HIS4
VAG-COM Discussion
08-26-2008 09:31 AM
Tik-Tok
VAG-COM Discussion
08-11-2008 04:07 PM
Bob W.
09-07-2003 03:02 PM
PRGeno
VAG-COM Discussion
05-22-2003 04:39 PM
s54m3
10-25-2002 02:11 AM
Quick Reply: Problem with 402 module
