Help: Jerky Transmission after TCM FLOOD. 05 AR
-Recently fixed an 05 AR flooded TCM.
-Cleaned the circuit board as much as possible.
-Now, The car shifts gears but the transmission shifts very hard and clunky AND --Dash lights won't show which gear i'm in.
Anyone have experience with this or have an idea if it's a bad TCM? Is this limp mode? VAG cable is on the way but I'd love some help from the community.
Thanks in advance!
Thanks in advance!
LIM mod will freeze the forward gears and leave you with only 3rd gear, sometimes only 4th gear. If your TCM flooded you have a lost cause. I've tried to clean them and reseal them on many different mechatronics units and never get a good fix. Usually results in a come back, and I can't afford that as my reputation is on the line. I would just replace it. I have never had an issue with sonnax and revmax mechatronics units
hope this helps, Connor
dirtforwheels4kQ
01-19-2010 05:09 PM
NEED FOR SPEED
11-23-2000 08:10 PM
