No first gear!? Anyone with the same problem? Newbie
#31
I still cant understand your voltage drop. This is very bad. Have you checked battery and chassis grounds. I am sure you know all brown wires are grounds. Check them for resistance using your meter.
BTW, you should change your title to this thread to indicate your trans is a TIP. I almost passed right by it thinking it was a 6 speed with its usual 1st gear problem. There are some very bright TIP guys on this forum and QW that may think the same. (Scotty @ Advanced for instance ) You should also post it to QW.
#34
I shall try to change my title
And what is QW?? :/
Yep, battery and grounds is fine, at the terminal under the dash it gives about 12-13 volts
#35
Yeah my transmission is in limp mode, just drives in 2nd and 3rd and reverse
#36
#38
#39
QW would be QuattroWorld - Audi Enthusiasts - News, Discussion Forums, Media, Events and more and Scotty @ Advanced Automation is a transmission guru!
