No first gear!? Anyone with the same problem? Newbie
Old 02-09-2016, 07:28 AM
  #31
hqbmw1@gmail.com's Avatar
Originally Posted by glennlindh
Even with my Ross-Tech I can't find connection to the TCU!?
I still cant understand your voltage drop. This is very bad. Have you checked battery and chassis grounds. I am sure you know all brown wires are grounds. Check them for resistance using your meter.
BTW, you should change your title to this thread to indicate your trans is a TIP. I almost passed right by it thinking it was a 6 speed with its usual 1st gear problem. There are some very bright TIP guys on this forum and QW that may think the same. (Scotty @ Advanced for instance ) You should also post it to QW.
Old 02-09-2016, 07:25 PM
  #32
cameltrophyallroad's Avatar
sounds like tranny limp mode
Old 02-09-2016, 07:27 PM
  #33
that would be 4th gear and reverse, the "PRND" letters would all be solid on the display. most likely TCM or connections, VAG data should help.
Old 02-09-2016, 08:11 PM
  #34
glennlindh's Avatar
Thank You for input
I shall try to change my title
And what is QW?? :/
Yep, battery and grounds is fine, at the terminal under the dash it gives about 12-13 volts
Old 02-09-2016, 08:14 PM
  #35
glennlindh's Avatar
You don't think my Ross-Tech is enough?
Yeah my transmission is in limp mode, just drives in 2nd and 3rd and reverse
Old 02-09-2016, 08:15 PM
  #36
glennlindh's Avatar
Yep, all the letters shines
Old 02-09-2016, 08:20 PM
  #37
glennlindh's Avatar
Embarrassingly I have to ask, how do I change the title??
Old 02-10-2016, 12:59 PM
  #38
Thank You for input
And what is QW?? :/
QW would be www.quattroworld.com and Scotty @ Advanced Automation is a transmission guru!
Old 02-10-2016, 03:49 PM
  #39
glennlindh's Avatar
QW would be QuattroWorld - Audi Enthusiasts - News, Discussion Forums, Media, Events and more and Scotty @ Advanced Automation is a transmission guru!
Thank you
Old 02-11-2016, 05:05 AM
  #40
advancedautomotion's Avatar
It could be a number of things, all I can suggest is finding someone near you to diagnose it.
Quick Reply: No first gear!? Anyone with the same problem? Newbie
