no windows / no sun-roof operation
Old 09-17-2016, 03:51 PM
UP Rick's Avatar
Default no windows / no sun-roof operation
all fuses are good & power is at them..no windows work and sun -roof stopped while opening / had to close manually also over-head courtesy lights stopped working.vehicle cannot be locked with-out going into flashing mode of parking lights ,..,. any help much appreciated,,,,Rick in the UP of Mich
Old 09-23-2016, 08:06 AM
Northwestern's Avatar
Might be worth a look - had a similar issue a few years ago.
I have a couple pin size holes in my sun roof gasket that allowed water to push into my overhead control unit. Would only happen at highway speed. suddenly would have a lap full of water.
I still have the hole but i solved the issue with electrical tape (not ideal) but maybe someone can point to a gasket replacement?.?.?
Check the sunroof gasket and the door jam connection on the drivers side. sometimes the wires can crack or break.
you can pull back the rubber housing and peak.
Good luck hope this helps!
Old 09-25-2016, 06:48 AM
Banned
PaperToast's Avatar
get a vagcom scan done
there might be a code stored for some if not most of what your talking about
Justice
Audi Original "S" Cars
05-02-2009 11:54 AM
95C4
08-26-2008 07:12 PM
Darren
08-29-2007 05:48 AM
psychobabble
04-04-2007 04:56 PM
Pete S4
10-10-2005 06:26 PM
Quick Reply: no windows / no sun-roof operation
