Nothing was stirring, not even a mouse
car no work
Get a load of this gang,
I recently came close to ending the wagon's g22/csp sensor/fr charge valve induced hiatus; close being the essential word in that claim. As a result of a healthy dose of aimless thought and effort I was able to get to the bottom of a few headaches. Having missed driving the wagon for a few weeks I began to get a bit antsy as I was buttoning her up. In eagar anticipation to take a dusk canyon stroll, I jumped in the drivers seat, popped in the key and... The battery is dead, really dead. Unfortunately an inconspicuous gps was sleeping in there, plugged in for the whole time and it ate every single once of energy contained in that battery. Being a brand new battery I figured I could save it. I charged it on the least aggressive setting for almost 2 days and sure enough when I got in today the dash lit right up and the gauge read 12v, looks like we're In business; have I learned nothing? I turned the key and absolutely nothing, no turn over, no solenoid, not even a dim of the lights. I'm fairly certain it's not the starter for the one In there isn't more than 2 months old.My best guess is that although the battery can keep the lights on, it doesn't have the ***** to hold any real load. Any Kind of input is welcome, hopefully somebody has some interesting ideas.
Car battery discharged
I recently came close to ending the wagon's g22/csp sensor/fr charge valve induced hiatus; close being the essential word in that claim. As a result of a healthy dose of aimless thought and ruthless effort I was able to get to the bottom of a few headaches. Having missed driving the wagon for a few weeks I began to get a bit antsy as I was buttoning her up. In eagar anticipation to take a dusk canyon stroll, I jumped in the drivers seat, popped in the key and... The battery is dead, really dead. Unfortunately an inconspicuous gps was sleeping in there, plugged in for the whole time and it ate every single once of energy contained in that battery. Being a brand new battery I figured I could save it. I charged it on the least aggressive setting for almost 2 days and sure enough when I got in today the dash lit right up and the gauge read 12v, looks like we're In business; have I learned nothing? I turned the key and absolutely nothing, no turn over, no solenoid, not even a dim of the lights. I'm fairly certain it's not the starter for the one In there isn't more than 2 months old.My best guess is that although the battery can keep the lights on, it doesn't have the ***** to hold any real load. Any Kind of input is welcome, hopefully somebody has some interesting ideas.
You didn't indicate whether you checked the voltage at the battery (my apologies if you did) but I would check that and assuming the battery is at full charge I'd next check the cable connections and resistance of both cables at battery, starter and ground. Assuming all is well there could it be an issue with the immobilizer? If the battery is still discharged I would give it a full aggressive charge (not a slow trickle charge). A new battery should be able to endure a complete voltage run down and then accept a full charge.
The battery is fully charged, just over 12v iv checked all the starter to battery lines for continuity and all is good in that department. I'm now fairly certin that there's some kind of reset that needs to be done because when you go to start the car it behaves as it would if you weren't in park or you didn't have the brake on or something, you turn the key and basically the ecu won't let the car start for whatever reason. If anybody has any Information on a reset of some kind I think that may be the ticket.
From what I could see on the cluster voltage meter it was just over 12v which equated to 13.2 when I tested it. Figuring it's possible that it just can't hold a load I tried a 14.0v Touareg battery and a 13.8v jeep battery, both yielded the same result, nada. So again I'm pretty sure it's not the battery. I tried about every reset sequence I could find and nothing, I'm hoping it's a relay or something and not the starter.
