Which OBD-II readers to buy?
Ok since I am new to the Audi side of things, I have a regular OBD-II reader. I know that I can not do anything with the Audi with it.
So which Vag-COM should I go for?
Vag505 also what is the big difference in the different ones? Which one will give me the most bang for the buck to change items with the Audi?
Thanks for any and all info that is provided.
Edward
Edward
Hi Edward,
I just got an allroad and it seems most people recommend buying one of the USB cables and full version of the VAG-COM software from Rosstech ($350 ish). Their software only works with their own cables, and will allow you to do everything short of programming your audi to pick you up from the airport.
Rather than paying that much I bought a cheap ebay cable (search for VAG-COM cable) and then downloaded VCDS-lite from rosstech, which is the free software they released that works with the ebay cables.
It has limited functionality, but now that I know how it all works I am going to buy a license from Rosstech ($100), which will allow to me unlock the full features of VCDS-lite.
For me this has just enough bang for my buck, but depending how serious I get I may buy Rosstech's own cable down the road.
I started with the Autel VAG505.
This is a good code reader, and does read all the codes the Ross tech unit reads, and it can do the service resets.
It will not do the basic settings and adaptations, or do diagnosis using the measuring blocks etc. To try to print the results was also painful. I used to just use a pen and paper.
Once you need to do 1 adaptation, you commit to the vag-com and then the VAG505 sits up on the shelf with all the other obsolete toys gathering dust.
Just my experience.
Just my experience.
Foxwell
Edward
Edward
Hi Edward,
Jyizorz
06-05-2007 07:05 AM
karimdurham
13
03-25-2007 12:26 AM
/\/\ightar
01-22-2006 08:35 PM
