Vag Login Codes
Old 12-27-2010, 08:18 AM
francoisd2446's Avatar
Default Vag Login Codes
Has anyone got a list of login codes for Vag Com for 2000 Allroad. Thanks
Old 12-27-2010, 06:10 PM
choptt's Avatar
nobody has a complete list except for me!!.not even the dealer or apr. ive scoured the forums,net,the ecu with hex editor,and by pure luck trial and error for a month discovered a few. i have over 12 engine login codes,each with there own magical power. 10 abs login codes, 3 suspension login codes, and pretty much all other login codes for the rest of the control moduals you have plus others you don't.and a few super secret basic settings adaptation tricks from vag that nobody knows but me. pretty much any and all audi/vw login codes from 1995 to 2009+,
you need them/want them, let me know
The following 2 users liked this post by choptt:
malros (01-05-2023), realmexyaudi (05-22-2023)
Old 12-28-2010, 11:58 PM
s4master1's Avatar
Default login codes
Very impressive
Skykar (03-27-2022)
Old 12-29-2010, 09:09 AM
Mike B's Avatar
Need the. Want them. I'm ready.
Old 12-30-2010, 02:38 PM
05allroad's Avatar
Post 'em up!
Old 12-31-2010, 05:37 PM
choptt's Avatar
use at your own risk.
engine
11463 ACCT CRUISE
16167 DEACTIVATE CRUISE
13647 ACT ADAP CRUISE
50000 AFTER RUN WATER PUMP ON
60000 AFTER RUN WATER PUMP
10016 DESIL PARTICAL FILTER ADAPT
21295 DESIL PARTICAL FILTER ADAPT
12233 TDI SPECIAL
01283 NDBW AND SOME NEWER
45678 SPECIAL CUSTOMER SERVICE LOGIN
ABS
40168 GENERAL
27861 GEN ENABLE ADAPT
13204 FWD
13504 AWD
23049 FWD ESP
18446 AWD ESP
09399 SPECIAL A6
00212 MK60
19469 MK60
04097 DBW
01025 NDBW
AIRBAG 20324
TDI 12233
CLUSRER 13861
SUSPENSION
31564 LOGIN GENERAL ENABLE
10273 TRANSPORT ACT
41172 TRANSPORT DEACT
Old 01-04-2011, 11:26 AM
N'Syncro's Avatar
Thanks Choptt!!!
Old 01-05-2011, 06:26 PM
choptt's Avatar
your welcome. if you wanna turn off the 02 sensors for testing, basic settings on mb 99. 107 is fuel pump, got to press the brake and gas at the same time for it to do its adaptation. people think that there is only the TB adaptation, there is a ton more if you now what your doing.
Old 11-15-2017, 12:55 AM
Tim362's Avatar
engine
11463 ACCT CRUISE
12233 TDI SPECIAL
ABS
40168 GENERAL
13204 FWD
13504 AWD
23049 FWD ESP
18446 AWD ESP
09399 SPECIAL A6
00212 MK60
19469 MK60
04097 DBW
01025 NDBW
AIRBAG 20324
TDI 12233
CLUSRER 13861
SUSPENSION
10273 TRANSPORT ACT
Hi Choptt and all,
I'm trying to tell my 2007 A4 B7 2.0tdi 170bhp that it has a new DPF, I've tried the 12233 code for security, but it says its wrong, and if I just go straight to Adaption it doesn't seem to do anything, are there any other codes for this model, or another way to tell it that it has a new DPF. I'm using a genuine Ross Tech VAG COM lead with the latest software and firmware.
Many Thanks
Old 11-15-2017, 02:32 PM
Banned
PaperToast's Avatar
Originally Posted by Tim362
Hi Choptt and all,
Many Thanks
its wrong because those codes are for the c5 allroad, not b7 a4
go to that section and post there
Quick Reply: Vag Login Codes
