Really don't know
Old 01-29-2015, 12:47 PM
RichardoRoss's Avatar
Default Really don't know
Hello guys,
I'm new one here, so if I write something as it should not be please let me know
So my problem seams to appear recently to a lot of AR users, but still digging true topics didn't found the answer.
Yesterday driving from job after turning right the side flashing signal from flashing went to fixed, but after few minutes fixed light again turned back to normal. I though its just a kind of silly problem, but day after as i woke up i saw that my car in parking place stays with fixed emergency lights ( all of them ). I tried to change the relay, but it didn't help, also i disconnected my battery and tried the bulbs and fuses. Guys I really don't know what to do here since every thing i possible could do i think i have done..
Some suggestions and maybe some of you could handle this kind of problem..
Old 01-29-2015, 01:55 PM
G0to60's Avatar
Hmmmm, since you've replaced the relay it may be something to do with the actual turn signal stock. Perhaps the switch inside there is sticking causing the weird lighting. Just a guess because I really don't know.
Old 01-29-2015, 02:02 PM
urs6_ma's Avatar
Welcome to the forums. I can't help you with your technical question...but I can make these two suggestions:
Use a good descriptive title for your posts. "Really don't know" isn't helpful and won't get a lot of people to read your actual post.
Second, provide good information about your car -- year, model, engine, mileage, how long you've owned it, etc. This will help us to better respond to your question with useful information...
Old 01-29-2015, 05:30 PM
John535is's Avatar
When you say 'relay', are you talking about the hazard light switch mechanism?
Mine had similar symptoms, the hazard light switch is also the indicator 'flasher'.
Sometimes it would blink once then stay on, other times it would start to blink the go off.
Part number 4B0941509KB98 (for my 2004).
To replace, pry the trim off from the bottom edge (use something flat so you don't damage the soft feel radio trim, old credit card or similar), the hazard switch has a clip on each side, pull forward, pull forward, 1 large connector on the back.
Old 01-29-2015, 11:27 PM
John535is , yes i did mean a hazard light switch since that is the relay in my car.. That didn't help..
Old 01-29-2015, 11:31 PM
urs6_ma, Thanks for additional remarks. Will provide better posts i future.
And i have Audi Allroad 2002 2.7 BiTurbo, with mileage 179 000 ( for 2 years now )
Old 02-03-2015, 01:36 PM
indoor's Avatar
Where did you buy the new hazard switch? It could still be defective, especially if nothing changed after replacing it. Does it say OEM China on it?
Otherwise, turn signal stalk is bad, like it was suggested before.
Old 02-09-2015, 09:36 AM
I bought it from car part Diller In my country (Latvia) and yes it does say OEM China. But I took original from neiburns car and no changes...
etaudi
Audi allroad
05-08-2023 11:06 PM
Agent008
Audi A3 / S3 / RS 3
09-01-2009 05:34 PM
SiV6Qcoupe
Audi 100 / A6 (C4 Platform)
12-01-2003 02:15 PM
Kron
12-12-2002 09:49 AM
S4_downunder
10-27-2002 05:34 PM
Quick Reply: Really don't know
