Saggy bottom
Old 01-19-2017, 10:16 AM
stephenmarr's Avatar
Default Saggy bottom
Hi guy newish to the forum.
Ive a 2002 Allroad 2.5TDi
over the last week or 2 when i leave the car for a few days the rear sags evenly on both sides.
usually leave it on level 2 when parked up.
i have it set on level 4 with jack mode enabled tonight.
Is there anything else to check?
Old 01-19-2017, 11:52 AM
snagitseven's Avatar
It sounds like you either have a pair of air springs that are leaking (usually it's only one corner) or a bad control block. Could also be a leaking air line. There are many threads on the air suspension system. Do a search.
Old 01-20-2017, 02:10 AM
amiram's Avatar
Still with the original rear air springs? Usually the air leaks is detected in the airbag Maybe first look for air pressure leaks from air pressure connections on the valve block and on the rear air springs ( 3 connectors on each unit )
Attached Thumbnails Saggy bottom-possible-locations-air-leakage-rear-air-spriag.png   Saggy bottom-compressor-dryer.jpg   Saggy bottom-valve-block.png
Old 01-20-2017, 12:53 PM
Well checked it overnight at level 3 with jack mode enabled didnt sag.
going to leave it overnight at level 2 with jack mode enabled.
will update.
Old 01-24-2017, 08:50 AM
Hey all bit of an update.
I left it for 2 nights on level 2 with Jack mode enabled and both sides have sagged.
Will leave it in level 3 over next few nights and see what happens.
Why would both sides drop on jack mode?
Old 01-25-2017, 07:07 AM
MrKid's Avatar
Jack mode does not "lock" the shocks in place. That just over rides the computer from trying to level car while it is on a lift or being jacked up.
The air shocks usually leak at level 2, because that's where the car spends most of it's time. They leak at the spot where the bladder folds on the shock. When you go higher or lower, you "seal" the leak.
I have good set of used shocks, because I swapped to coil overs. If your interest, I can pm you a price.
Old 01-25-2017, 08:32 PM
Reminder, no offers to sell or buy in the discussion forums. Use PM or the classifieds.
sr28Q
06-20-2018 03:04 PM
sr28Q
06-20-2018 05:30 AM
A5allroad67
Audi allroad
09-17-2017 09:07 PM
glhglh
Audi allroad
19
09-20-2013 06:49 AM
sugaryling
Audi allroad
10
08-28-2007 05:36 PM
Quick Reply: Saggy bottom
