Simple question - air ride
Hello, I don't own an Allroad yet, but I'm in the market for one, and I'm going next week to look at one, and I'm hoping y'all can give me some pointers on what to look for, and if there's a way to test the air ride. I'm assuming that if there's a problem with the air springs or whatever that they will sag and whatnot, but if I set it on max height setting and test drive it a little bit, would that be the best way to test it? I know the timing and water pump have already been replaced, the fuel pump, filter, and relay have been replaced, and it's been well maintained. What worries me is that the front air shocks were replaced, but not the rears. Is that a good indicator that the rears will need replacing soon?
Like I said before, I'm just wanting some pointers on what to look out for when I look at it. I used to work as a mechanic, so I know the basics, but I'm kinda new to foreign stuff!
Thank you in advance for any help, it's much appreciated.
Diagnosis
I have a code scanner, but I'm not sure if it can read Audis. I've already started researching the vag-can scanners on eBay, do those usb cables on there require certain software to program and such? The few I've looked at come with some disk, but they don't list any specific software or anything. I'm going Tuesday to look at an 05 Allroad, I'm pretty excited!
Stay away from the eBay scanners. Get your VAG-Com directly from Ross Tech.
Without the software, I would run the car from level 1 to level 4 and see how long it takes. If the compressor times out, you most likely have a leak or need a compressor rebuild.
Also, check around the heads to see if you have oil leakage. Expensive to have fixed, time consuming to do on your own.
Thank you
Thank you for your help! I'll be having some more questions sooner or later, but so far the search function on here has helped quite a bit.
Those are pictures of the one I'm going to look at Monday or Tuesday. I can't wait!
if any corner does sink its easy enough to fix but knock a good bit off the price
regards
Andy
Amazing shape!
Well I bought it yesterday! No sag after looking at it, next morning, still no sag, so I think I lucked out for now. It was a forty mile drive home, in the rain, and it was amazing! Engine makes no noise, seller had all the service records and all the normal stuff (timing belt, water pump, valve covers, air bags, air bag compressor, fuel pump) was done between 160,000 miles and 190,000 miles. New tires at 185,000, interior in great shape, headlights are hazy, but no biggie. The front seat armrest lid catch is broken, but that's not too concerning, got about 23 mpg on the drive home, which was nice! Has a broken passenger side fog light, so I'll need to replace those of anyone has a set or just one they want to sell me on the cheap. Check engine light is on for a couple of emissions things, but nothing I care too much about right now. Took some pictures just now before I head up to the DMV to get plates and such.
Anyways, thank you all for the help so far! I'm sure I'll be having more soon!
I don't want to rain on your parade, but it looks like you have it set to level 3 or 4. My bags leak bad if I leave it at 2, but if I leave it at 3, they hold. Just something to check out.
Overall, looks very clean and well maintained. Good luck, and enjoy it!
OneGuyInCA
11-11-2007 02:42 PM
kaynos
10-21-2007 06:41 AM
