Suspension Problem of course. Valve block, suspension module, or something else all?
I don't have access to a vag com just yet but I may be able to find on locally (slc, utah) but here's what happened. I was pulling up to a stop and all of a sudden it sounded like a valve opened and was dumping air. It didn't sound like a leak or a burst bag, I've had both of those before. Got out and both fronts were still at 2 or 3 I forget, but both rears were completely empty. Since then the fronts have lowered to their bump stops as well and none of them have filled up since. Anything in particular I can try to fix my problem or at least get me closer to knowing what's happening?
Got my vagcom in the mail and it's got all sorts of fun errors.
Friday,10,June,2016,23:26:32:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x64
VCDS Version: 15.7.0.2
Data version: 20150820
Ross-Tech: Home
VIN: WA1YD64B24N027984 License Plate:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2006))
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 S
Component: 2.7L V6/5VT G 0020
Coding: 07755
Shop #: WSC 02334
VCID: 53BC6F576BF5B8AAF222411-515E
WA1YD64B24N027984 AUZ7Z0C2452410
12 Faults Found:
17965 - Charge Pressure Control
P1557 - 35-00 - Positive Deviation
17545 - Fuel Trim: Bank 1 (Add)
P1137 - 35-10 - System too Rich - Intermittent
17547 - Fuel Trim: Bank 2 (Add)
P1139 - 35-10 - System too Rich - Intermittent
19497 - Powertrain Databus
P3041 - 35-10 - Implausible Engine Temp. Message from Inst. Panel - Intermittent
17865 - Exhaust Gas Temp Sensor 2 (G236)
P1457 - 35-10 - Open or Short to Plus - Intermittent
19537 - Engine Temperature too Low
P3081 - 35-00 -
17862 - Exhaust Gas Temp Sensor 1 (G235)
P1454 - 35-10 - Short to Ground - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16685 - Cylinder 1
P0301 - 35-10 - Misfire Detected - Intermittent
16688 - Cylinder 4
P0304 - 35-10 - Misfire Detected - Intermittent
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
16395 - Bank 1: Camshaft A (Intake)
P0011 - 35-00 - Retard Setpoint not Reached (Over-Advanced)
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4Z7 927 156 M
Component: AG5 01V 2.7l5VT USA 2122
Coding: 01002
Shop #: WSC 02334
VCID: 50B6605B5AE3C3B2CF40A65-5140
1 Fault Found:
17095 - Transmission Fluid Temp Sensor (G93)
P0711 - 35-10 - Implausible Signal - Intermittent
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D56
Coding: 06497
Shop #: WSC 02335
VCID: 4A827233BCBFF9628184E4D-515E
No fault code found.
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AR
Component: A6-Klimavollautomat 0208
Coding: 00010
Shop #: WSC 00000
VCID: 6AC2D2B3DC7F1962A14444D-2580
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4Z7 959 655 J
Component: Airbag 8.4EP 3000
Coding: 0000607
Shop #: WSC 02334 785 00200
VCID: 56BA96437807A882153C60D-515E
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01002
Shop #: WSC 02334
VCID: 2F7403A7271DBC4AB6BADD1-5140
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 P
Component: KOMBI+WEGFAHRS. VDO D14
Coding: 06264
Shop #: WSC 00000
VCID: 337C0FD7CB3598AAD262E11-5140
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
01304 - Radio
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 F
Component: - 2C1A1 X060
Coding: 25500
Shop #: WSC 19400
VCID: 4886483BA2B30B7297B0CE5-515E
4 Faults Found:
01577 - Turn-Off due to Over-Temp
35-00 - -
01771 - Control Module for Headlight Range (J431)
79-10 - Please Check Fault Codes - Intermittent
00774 - Level Control System Sensor; Rear Left (G76)
57-10 - Electric Circuit Failure - Intermittent
01400 - Suspension Level Control
11-10 - Control Limit Not Reached - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D38
Coding: 15885
Shop #: WSC 19502
VCID: 337C0FD7CB3598AAD262E11-4ECE
11 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01561 - Rear left door
59-10 - Can't Unlock - Intermittent
01574 - Alarm triggered by Door Contact Switch; Rear Right
35-00 - -
01573 - Alarm triggered by Door Contact Switch; Rear Left
35-00 - -
01482 - Motors for Central Locking
29-10 - Short to Ground - Intermittent
01586 - Locking Cylinder Contact Switch; Passenger Side (F242); Close
29-00 - Short to Ground
01585 - Locking Cylinder Contact Switch; Passenger Side (F242); Open
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0204
Coding: 00001
Shop #: WSC 00000
VCID: 2C4E14AB160BC75293D8325-4B1A
3 Faults Found:
01455 - Driver's Seat Switch for Seatback Adjust (E96); Forward
28-10 - Short to Plus - Intermittent
01452 - Driver's Seat Fore/Aft and Height Adjust Switch (E61); Down
00668 - Supply Voltage Terminal 30
07-10 - Signal too Low - Intermittent
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00030
Shop #: WSC 02334
VCID: 041E9C0BDE1BEF123B48FA5-4B4C
End-------------------------(Elapsed Time: 05:14)--------------------------
Ross-Tech: Home
75 76 77
Coding: 07755
Shop #: WSC 02334
12 Faults Found:
P3081 - 35-00 -
16685 - Cylinder 1
16688 - Cylinder 4
Coding: 01002
Shop #: WSC 02334
1 Fault Found:
Coding: 06497
Shop #: WSC 02335
Coding: 00010
Shop #: WSC 00000
Coding: 0000607
Coding: 01002
Shop #: WSC 02334
1 Fault Found:
01304 - Radio
Coding: 06264
Shop #: WSC 00000
2 Faults Found:
01304 - Radio
Coding: 25500
Shop #: WSC 19400
4 Faults Found:
35-00 - -
Coding: 15885
Shop #: WSC 19502
11 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 00001
Shop #: WSC 00000
3 Faults Found:
Coding: 00030
Shop #: WSC 02334
It does run and I get the orange suspension light in the cluster flashing. The lights on the level buttons seem to be acting normally. It sounds like it is just blowing air somewhere towards the back. I'm going to pull it into my warehouse later today and check it out.
Banned
Coding: 25500
Shop #: WSC 19400
4 Faults Found:
35-00 - -
01577 compressor getting hot from running too much, check for leaks (never hurts to so this regardless)
00774 that sensor died, replace it; new from the dealer is going to be close to $200, source a good used one if you can
01400 your going to have to reset the ride heights, search for '402 mod' to get the proper procedure
01771 should go away when you address the 3 problems here
Coding: 25500
Shop #: WSC 19400
4 Faults Found:
35-00 - -
Cool, Thanks a bunch. I'm pulling it into the shop today to swap out my cv axles so i'll look at that sensor also.
Sounds to me like you lost a Pneumatic supply line to the rear. You can buy a 50 ft roll of the line on Amazon for about $25 and its enough to do the whole car and half of another car. while you are at it go ahead an order a new compressor piston ring from Bagpipe Andy in the UK. Be careful when you disconnect
the Plastic line from the distribution block to capture all of the old fitting pieces. The Color of the line sold by Amazon is black. The color doesn't matter once the vehicle leaves the factory. I've seen far more plastic line failures than Strut or Distribution Blocks go bad. And yes I've changed them all for no reason what-so-ever. Bagpipe Andy also carries spare compressor Piston Assemblies as well as Replacement Compressor Cylinders for the WABCO Compressors.
Dixon 1091P0401 5/32 Pneumatic supply line At Amazon.com they even sell the ferrules and nuts as well
Bagpipe Andy courtesy of eBay UK. Super helpful and dependable.
My 2002 allroad has a solid orange suspension warning light, except very occasionally it randomly flashes when the vehicle is in motion. The code is 00776 which indicates a fault with the front left level control sensor. That has been removed from the vehicle but no issue such as corrosion is visible. Is there a way to bench test the sensor with a multimeter? I do not have a wiring diagram. Is there a trick to disassemble the connecting plug so it can be checked for corrosion?
Thank you for any assistance.
W Digby
W Digby
