Is there a secondary air injection system in the 2.7T 6MT?
C5 Allroad 2.7T 6MT
I recently threw CEL P0492 - Insuficcient flow, secondary air injection system, bay 2. I figured it was a cracked hose because it was only one code rather than 2, but when I opened my (Bently Publishing) service manual it said, "Secondary air injection is used in normally aspirated engines, and in turbocharged engines with automatic transmission. [pg 26-10]."
What gives? I ran the VIN to make sure nobody swapped the tranny and it came up with 6spd. Even comparing the schematic to my engine, I have the air injection pump motor in the correct location even though it says that should only be there in the auto.
Is the secondary air injection system supposed to be in the 2.7t with a manual tranny?
Thanks in advance!
Thanks in advance!
Do yourself a favor: go on ebay and buy a cd repair manual for $15. Yep, that is right, $15. Beats the Bentley cd, because it has a whole lot of audi models, AND you can PRINT all the pages you want. And I verified the info against Bentley cd: all the same. I have all three: Bentley paper, Benttley CD, and bootleg ebay cd
Even a PDF version is more useful: because you can print. I got one of those for my Jetta. It's not as easy to find things(thousands of pages), but once you get used to it, it's not that bad...
As far as why your car has SAI when its a manual, I notice the later years, like 04-05 all have it regardless of Auto or manual. The early 2.7T cars manuals never had it.
I have a 2001 6mt and it has a SAI pump. It's bitchin' on cold stars for a few minutes
Which brings the question? Does anyone know why is there a relocation kit for it? I know i read somewhere about it. Cant remember if here...Also anyone know the part number for the kit?
THM
VAG-COM Discussion
09-18-2007 01:17 PM
audilover917
05-22-2007 11:53 AM
