Visco clutch fan PULLEY removal
Is there a way to get the PULLEY off (fan is long gone) without taking all the timing belt stuff off (to remove the pulley and bracket as a whole)?
Yes you can
Yes you can. Note that two bolts are hidden in the inner side of the pulley. You must insert the allen wrench through one of the hole in the pulley (5mm) to access one and a slot to access the other. 4 bolts in all. Three 6mm and one 5mm.
aluminumpork
11-21-2017 07:14 PM
a6killa951
02-10-2008 01:23 PM
