Warning about new Arnott Allroad shock absorbers
#22
PLEASE MAKE A FIX FOR YOUR PLASTIC AIR BAG TOPS
Hi Doug,
Ran across this post. I got an airbag from a friend. threads were stripped without him knowing. This is a very common problem. Would you please come up with a fix for this manufacturing defect. I recommend a metal fitting that can be tapped into the top of the bag and then put in the voss fitting.
Mark.
Mark.
Please contact Arnott regarding your shocks at 321-868-3016 or +31 (0)73 7850 580 in the EU. You may have counterfeit items since Arnott does not offer a rear replacement shocks for the allroad (C5 or C6) at this time. Our new front shocks are manufactured for Arnott by a leading shock manufacturer using our specifications for valving and quality and are backed by Arnott's Limited Lifetime Warranty in the US and EU. They were well tested and customer feedback has been overwhelmingly positive. We are currently working on and testing new affordable, high quality, rear shocks which we hope to release soon but at the time of this post the company does not offer rear shocks.
Here are Arnott's current suspension options for the 2001-2005 allroad:
EU: https://www.arnotteurope.com/audi-a6...-products.aspx
US & Non-EU: https://www.arnottindustries.com/par...17_pid206.html
#23
Air springs
I ran with couple rear Arnott's been 3 years more than 100,000 KM, The Front replaced about a year ago, with a new model ( Conti Tech bags.) All this under the lifetime warranty. Excellent Customer Service.
recommended
recommended
#24
Exactly. That is why I switched to Audi originals that I can professionally overhaul in a truck airpspring repair shop. That is nonsense that man can fit the Voss fitting only once and later a air blows off slowly at the thread.
The metal fitting is also questionable on the head as a whole Still in 2013 when I used the Arnott bags and was very careful with the assembly, However, one torx pulled out the metal fitting at only 18Nm. I did not complain just glued the fitting back. Therefore I would recommend to return to the alloy version.
Bogdan_94
09-13-2017 09:42 PM
T-28-Quattro de VT
09-03-2001 07:54 PM
T-28-Quattro de VT
08-29-2001 02:45 PM
