Auxiliary Fan Clutch
Old 03-27-2014, 03:43 PM
tommyt50's Avatar
Default Auxiliary Fan Clutch
any clues how to replace Auxiliary Fan Clutch on a 2002 allroad
Old 03-28-2014, 06:07 AM
G0to60's Avatar
Do you need to replace the whole fan or just the clutch? Remember that the clutch part is a reverse thread so you turn it right to get it off.
Personally, I'm going to be removing the clutch fan and replacing it with an electric fan. I'll probably go with this kit from JHM.
http://jhmotorsports.com/shop/catalo..._66_68_192_208
Old 03-31-2014, 04:04 AM
Kneale Brownson's Avatar
Not too tough:
https://www.audiworld.com/forums/sho....php?t=2828873
Old 03-31-2014, 04:43 AM
tommyt50's Avatar
Just replacing the clutch looks to me as though the fan blades are still in good condition
Old 03-31-2014, 05:34 AM
amiram's Avatar
Default Opening Direction
Hope this help, (Previous picture of the engine 2.5 TDI sorry)
Old 03-31-2014, 06:35 AM
G0to60's Avatar
Look over the fan blades closely. They tend to crack with age and can come apart sending pieces into your radiator and hood. If you are going to replace the clutch I would also look into replacing the fan blades as well.
Old 04-01-2014, 03:15 AM
silverd2's Avatar
Originally Posted by amiram
Hope this help, Use the two Wrenchs 32 mm
Can't imagine how that misinformation (Elsa-Lose?) would help. No Audi clutch fan I've ever seen takes TWO 32mm wrenches...not a USA Allroad or my D2.
The clutch and fan are removed by an adjustable (or dedicated "fixed") pin wrench (which fits holes in the pulley to hold it in place) and ONE 32mm long flat wrench (made for viscous fans). The 32mm nut has reversed threads.
Bentley recommends removing the front end (bumper/lock carrier), but I've done this a couple of times by simply removing the inter-cooler tube on that side, to leave space to remove the clutch/fan.
If you have many miles at all on those fan blades, I'd change em...the all go bad eventually in AR's >>>
http://forums.quattroworld.com/allro...s/137796.phtml
huwla
12-03-2007 08:52 PM
urs6ville
Audi Original "S" Cars
11-30-2006 02:06 PM
shostang
10-29-2006 01:35 AM
Onemax
12v V6 Discussion
03-17-2003 05:47 AM
dlkramer
10-21-2002 06:06 AM
Quick Reply: Auxiliary Fan Clutch
