BIRA Brakes
BIRA Brakes
Hi,
First time here. I have a 1995 S6 with Porsche 4 piston red calipers on it.
I just finished replacing the rotors and pads. When I took the rotor off I noticed that the aluminum bracket that the caliper is mounted on is very, very corroded. Does anyone know where to go to get a replacement made maybe out of stainless steel. No electrolysis with Stainless.
Thanks,
Gary J
Thanks,
Gary J
Hi, First time here. I have a 1995 S6 with Porsche 4 piston red calipers on it.
I just finished replacing the rotors and pads. When I took the rotor off I noticed that the aluminum bracket that the caliper is mounted on is very, very corroded. Does anyone know where to go to get a replacement made maybe out of stainless steel. No electrolysis with Stainless. Thanks, Gary J
Apikol UrS4/S6 Boxster S Brake Brackets
* Use with OEM Audi A8 323 x 30mm brake rotors (P/N: 4D0 615 301J).
* Use with Porsche Boxster S Calipers (or equivalent) brake caliper: P/N: 996-351-425-11 and 996-351-426-11
Apikol UrS4/S6 993TT & 928GTS Brake Brackets
BIRA Brakes
Hi UrS4boy,
Thanks for the help.
You mentioned that the machined steel bracket from Apikol (with some pre-emptive corrective machining to correct a 1 mm issue) would work.
Can you please explain where you need to remove the 1mm?
Thanks again,
Gary J
Thanks again,
Gary J
Click on this link (and book mark it when it is up), then click on the Front Brake label to find out more about C4 UrS Front Brake options:
http://members.shaw.ca/ajmills/UrS%20chassis%20Map.html
