Callout for the Above ECU Fuse Panel Fuses - UrS4 and UrS6 differences - AudiWorld Forums
Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Old 06-22-2014, 10:32 AM   #1
UrS4boy's Avatar
Default Callout for the Above ECU Fuse Panel Fuses - UrS4 and UrS6 differences
Up until recently I did not know that the fuse panel above the ECU was different between the UrS4 and later UrS6s. Not only do the later UrS6s use straight up fuses, in three of four cases, they are also called something else . Furthermore the UrS6 S75 fuse seems to be 10A not 12A like the UrS4 thermo fuse. Here is some info that I hope you can confirm or deny or provide suggestions for improvement.
Above the ECU Fuse Panel Callout (See table below images)
Thanks to Jamu (EmeraldUrS4) for the base photo
Thanks to DaTrem for the base photo
Here is the above-ECU-fuse panel on a RHD 1996 UrS6 (in this case also an autobox car):
Unlabeled base photo courtesy of Popdemonic in Thailand
Here is a UrS4 Above-ECU-fuse panel released from its above-ECU mount to better show the wires:
The wiring for this auxilliary fuse panel is bundled together (mostly) and heads towards the centre tunnel and then to ??? The White/blk ECU power from the ECU power fuse holder has to join the T55 bundle somewhere close.
Here is the panel with the UrS4 S26 fuse holder removed to show the back of the fuse holder wiring. The white wire with the black stripe ends up in the T55 ECU Connector bundle at Pin 55/18, as listed in the ECU pin-out post.
UrS4boy is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
PARTING OUT 2002 A4 B6 1.8T Cmmartin23 Parts For Sale 26 08-23-2016 05:44 PM
The Daily Build..My S6, the story and the questions vwleadfoot Audi Original "S" Cars 4 12-24-2015 07:07 AM
Just had service on 2014 S6. Can anyone verify I have latest ECU/TCU software? Dr Chill S6 (C7 Platform) Discussion 1 11-05-2015 10:25 PM
Window drop issue w/ radio staying on chubs636 TT (Mk1) Discussion 3 09-14-2015 04:42 PM
Q7 Fuse questi bagsformom Q7 Discussion 1 09-09-2015 05:34 PM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
