Camshaft position sensor error ......help?? - AudiWorld Forums
Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Old 07-13-2008, 08:43 PM   #1
Default Camshaft position sensor error ......help??
Hi Guys,
About 5 months back I started getting a cam position sensor fault code, so I had it replaced to avoid getting stuck one day. About a week ago I got a check engine light, checked, and it was the camshaft sensor fault again. As it was under warranty, I had the sensor replaced.
All seemed well until over the weekend I was driving on the highway, and all of a sudden the check engine light comes on.
Checked and it is the same fault code. :-(
I pulled the timing belt cover and everything seems fine with the sensor. The wires leading to the connector, next to the injector rail, seem fine as well.
Here are the errors I am getting on the VAG. I cleared them but they keep coming back, even at idle now.
00515 - Camshaft Position (Hall) Sensor (G40)
29-10 - Short to Ground - Intermittent
02-10 - Signal Shorted to Ground - Intermittent
Should I be testing continuity from the large ECU plug to the connector for the CPS? Is this what the errors are pointing to?
If anyone has experienced this I would appreciate any information.
Thanks.
TO1993S4 is offline   Reply With Quote
Old 07-13-2008, 11:32 PM   #2
UrS4boy's Avatar
What did you replace the CPS with? OE Bosch or BB Automacao BBHME301?
UrS4boy is offline   Reply With Quote
Old 07-14-2008, 05:41 AM   #3
Replaced it with Bosch
Old 07-14-2008, 08:46 AM   #4
UrS4boy's Avatar
Default Then all you can do start with is check for continuity of the wires back to the ECU. Otherwise, you
will be into changing it. Seems strange that it would fail so hope for a pinched wire somewhere.
Old 07-14-2008, 08:57 AM   #5
Thanks. I'll check and see what I find from the ECU harness back to the plug for the sensor.
Thread Thread Starter Forum Replies Last Post
"Login lost due to dropped session" constantly cameltrophyallroad Audi allroad 4 02-14-2016 08:18 PM
Help please! 2012 Audi s4 misfire after 4000 rpms VAG COM POST iestatic S4 (B8 Platform) Discussion 2 01-04-2016 02:28 PM
Looking to buy a crankshaft position.sensor for a.:2001 adobian Audi allroad 5 12-08-2015 03:06 PM
No Start, Need Codes Diagnosis eggsngrits A8 / S8 (D3 Platform) Discussion 0 09-05-2015 11:22 AM
Camshaft Position Sensor Location (3.2 FSi)? irelandbuyer A8 / S8 (D3 Platform) Discussion 2 09-02-2015 07:01 PM
Tags
00515, 18t, 2001, 27, a4, audi, camshaft, code, error, fault, g40, hall, position, positioning, sensor
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
