Can someone explain the button under the loud pedal ? - AudiWorld Forums
Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Old 06-15-2014, 04:14 PM   #1
Default Can someone explain the button under the loud pedal ?
Is that for the overboost? Sometimes my car runs very very well and sometimes it feels blah? How do you make sure the overboost works every time?
BB1995S6 is offline   Reply With Quote
Old 06-15-2014, 04:15 PM   #2
Is it a button or stop?
Old 06-16-2014, 12:30 AM   #3
UrS4boy's Avatar
It's just a stop.
UrS4boy is offline   Reply With Quote
Old 06-16-2014, 06:53 AM   #4
After a closer look that's what I had thought. But I still am not sure how overboost is called apon? It seems to only happen 40 percent of the time. But when it works it's noticeable.
Old 06-16-2014, 07:21 AM   #5
UrS4boy's Avatar
Overboost is provided by the ECU and it depends on the RPM and throttle position switch position, i.e. wide open throttle. Overboost is only provided when appropriate and even then only for a maximum of 15 seconds.
Old 06-16-2014, 06:54 PM   #6
Thanks that helps a lot. There needs to be a full load switch.
Old 06-17-2014, 07:57 AM   #7
UrS4boy's Avatar
Quote:
I'll let the boys at Bosch circa 1991, via my way-back time machine, of your concerns.
Old 06-18-2014, 05:03 AM   #8
Quote:
That's the spirit.
moorewr is offline   Reply With Quote
Old 06-20-2014, 03:11 PM   #9
So when the car gets a custom chip can the tuner change the overboost? Or modify it? Or do you need to go stand alone em?
Thread Thread Starter Forum Replies Last Post
Fault Codes Kerry G Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 3 06-07-2016 03:55 AM
Shelby Monsoon Enough (break-in and other questions) Monsoonenough S4 (B8 Platform) Discussion 3 10-03-2015 03:59 PM
2015 Q5 TDI 5,500 miles...Glow Plug light flashing.. SJGQ5 Q5/SQ5 MKI (8R) Discussion 4 10-01-2015 09:44 AM
Weird noise that goes with the engine inside the car changareth Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-25-2015 12:27 PM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
