Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Frequently Asked Questions (FAQ), Procedures and Resources
Old 11-10-2013, 06:18 AM
  #131
Norbert Romeo Matashu's Avatar
Default Car Starts, runs for 2 seconds then runs really rough then dies
Car Starts, runs for 2 seconds then runs really rough then dies.
I have a problem with my 99 a4 1.8t...it will start up and idle but once i rev it, it bogs down and stalls, i plugged the ecu comp in and it read that the injector circuits are stuck open on all 4 cylinders...what do you think the problem could be ????...thanks for any help
Old 11-10-2013, 06:19 AM
  #132
Default Car Starts, runs for 2 seconds then runs really rough then dies.
Old 02-27-2017, 07:28 AM
  #133
kj6304's Avatar
Default Audi s8 bigger front rotor 4D0 615 301B
Originally Posted by UrS4boy
Credit to Trent Wakelin for these part numbers:
RS2 BRACKETS
8A0 615 125 A (034Motorsports or VAG Parts)
993tt Big Red Calipers:
993-351-425-10 (left), 993-351-426-10 (right)
Porsche 928 GTS front calipers
Porsche P/N -928-351-423-03 L, 928-351-424-03 R
Later A8 ROTORS (323x30, 5/112)
4D0 615 301 A or J (A was superceded by J)
Also:
Bolts, long (caliper to bracket, x4)
999.067.041.09
Bolt, short (Strut to bracket, x4)
N 100 880 03
Bolt size is: M12x1.25x25mm
Vibration dampers 44 mm (x4)
965 351 096 00
Vibration dampers 36 mm (x4)
964 351 096 01
Wear Sensors (x2)
993.612.368.00
Wear Sensor holders (x2)
928.612.361.00
Brake lines (x2)
443 611 707 C (rubber OEM, M-F, 405 mm long)
Or custom stainless steel
YMMV
Hello Dave,
So sorry to bother you but interested to know does the bigger s8 rotors at 345mm/30 is the same as the smaller 323mm/30 except bigger? I have a set of the Boxster S red calipers that I want to install on my 1994 URs4 with the adapters from Aprikol with 18" wheels.
Thank you in advance and best regards
Bobby
Winchester, Ma
Old 02-28-2017, 06:18 AM
  #134
UrS4boy's Avatar
A FAQ *WAS/IS* supposed to be a repository of information, not a point for questions and answers.
Contact Apikol with your question (they make the brackets that you will need):
Apikol Brake Brackets
Don't answer this post.
02ALMSTT
04-02-2009 02:05 PM
phil_3993
02-08-2006 05:36 PM
Audeye A6
03-23-2005 04:44 AM
scott12v@pghaudi
12v V6 Discussion
03-12-2003 05:44 PM
Audicted2quattro
05-27-2002 10:24 PM
Quick Reply: Frequently Asked Questions (FAQ), Procedures and Resources
