Just added these photos to the G40 Cam Position Hall Sender Info post
Here are some photos of the G40 Cam Position Sender and its wiring:
If you are clever, you can set up an LED to show you that the CPS is working properly by connecting an LED between Pins 2/3 and 3/3, using instructions written by Marc S. at EFI Express
Photo courtesy of Marc S. at EFI Express
MORE G40 Cam Position Sensor (CPS) info
Good stuff Dave. Pretty much what I did a few months ago, with a $2 LED from Radio Shack.
For me, just inserting the wire into the harness allowed the S6 to start on occasion, so I could get home to change the CPS.
*ps - I was away for a week so... Happy Birthday
Dave F.
Dave F.
Yeah, it was Marc's trick while I was waiting for the new CPS to arrive in the mail, and the longer leg went in the middle perhaps. I had cranked it a bunch, changed the fuel pump and cranked it more... all with no start. Then when I put the LED in to look for the "blink" it started, and I was able to drive it to the house and wait for the CPS.
Interesting (or confusing). I just realized that I had a packet of Radio Shack (The Source in Canada) LEDs. So I went out the car and tried the trick. Didn't work. (car wouldn't start). So I removed the LED and tried starting the car. It started. Hmm....I left it running and inserted the LED legs into the same location and I got a glowing/ blinking(ish) red LED. Okay. Shut off the engine and tried restarting. Nada. Crankety crank crank crank. Nothing. Remove the LED and tried again. Vroom. started right off. Hmmm...gonna email Marc. Dave F.
""Hi Dave. you did it right. I should add a note that inserting the LED can at times cause a no start. The reason is because the cam sensor is a very weak signal. So weak that the resistance from the LED is enough to drag the output voltage down enough to not trigger the ecu.
This doesn't matter in the context of a car that isn't starting (why most people would be testing the cps in the first place). If you have somebody else crank the car over you'll note the LED is blinking, even if your car is now not starting. Incidentally, on vems, it always starts up with the led in place (stronger 5v supply)."
UrS4boy
Audi Original "S" Cars
02-15-2013 10:21 AM
Justin517
08-31-2004 11:22 AM
ChaoticS4
02-13-2002 12:23 AM
madman0
09-08-2001 01:47 PM
