New member with a boost question - AudiWorld Forums
Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
LinkBack Thread Tools Search this Thread
Old 08-14-2014, 07:26 AM   #1
Default New member with a boost question
Hi all,
new to the forum. I have search but can't find an answer to my question. I have a 93 S4 with what I think in the MTM stage 3 chip as well as the 3bar map. Someone else put this in. My question is, is it safe to run this high of boost? I always get nervous over one bar that I'm going to blow up. What is the max boost that I should be running.
Additional information kkk 27, RS2 exhaust manifold, Audi sport lower intercooler. After market exhaust.
Sorry but I'm trying to figure out all the STUFF the guy put into the car so I do not have all the information yet.
Thanks
alby'sS4 is offline   Reply With Quote
Old 08-14-2014, 08:42 AM   #2
let me add and correct the first post. I'm do not feel comfortable running over 18lbs boost. Will these cars reliably run 28lbs boost?
Old 08-14-2014, 12:06 PM   #3
GoHeels's Avatar
I'm MTM stage 1+ with the 3.0 bar map. Don't have a boost gauge but believe I get ~22lbs of boost. Many run MTM stage 3 and have no trouble with the RS2 EM and bigger turbo. I imagine you are fine. You can usually hear "overboost" so just listen and be careful there.
GoHeels is offline   Reply With Quote
Old 08-15-2014, 04:45 AM   #4
Thanks for your reply. I have read through a lot more threads and it does seem like the engine can take around 27lbs of boost without issues. I purchased this car a many years back and just got it on the road. It was totaled. The guy before me did a lot of good mods but I'm not sure of all of them as of yet. Some of the mods make me think he was part of this or QW forum. His name was Ned from the northeast. Anyways, once I find out more I will post pictures and the build.
Thanks again
Old 08-17-2014, 09:45 PM   #5
UrS4boy's Avatar
For lots of UrS engine related info, check on the labels in this diagram:
http://members.shaw.ca/speedtek/UrS%...ice%20Map.html
PS: 28 psig is about the max a RS2 K24-7200 turbo will put out and the engine can handle it just fine, provided the software is not too aggressive and the fuel you are using is at least 92 (RON+MON)/2 (to help limit rod-bending pinging)
UrS4boy is offline   Reply With Quote
Old 08-18-2014, 10:26 AM   #6
Thanks for the information if I may call you Dave. I have read a lot of your posts and learned a great deal. I wish I could borrow you for 1/2 day to help me identify what was done to my S4. I'm sure you could tell me without me finding part numbers. Oh well. I'm actually have fun figuring out everything. Just going to take some time. I only run 92 US octane so I guess I should be ok. I took it out over the weekend and let her fly for a bit. Boost went up to 25-26 lbs. Man that felt good. Thanks again or all the help.
Old 08-18-2014, 01:21 PM   #7
UrS4boy's Avatar
Watch out for pinging on 92 and MTM 3. Will sound like nuts and bolts being shaken in a metal coffee can.
Old 08-19-2014, 05:24 AM   #8
No popping yet. It was about 87 degrees out also. Very electric on the way up. Anyways, I have to pull the ECU this weekend to see what was done to it. The old owner stated Joe Hoppen supplied a lot of stuff including the MTM stage 3 but this is unconfirmed at this point. From another source the old owner stated Superchip. Any ideas other than physically opening the ECU?
Thanks again for you help
Old 08-19-2014, 04:01 PM   #9
UrS4boy's Avatar
Default ECU opening hints
Hoppen might have put a label on the the outside of the ECU. They were MTM dealers so if they did the work, it would not likely be a Superchips "set" (which usually was only one chip in their game - typically not good, not liked).
ECU opening hints: http://12v.org/urs/Bob%20Myers%20ECU...structions.pdf
Old 08-19-2014, 06:20 PM   #10
Thanks for the link. I hope I will not need it. I am hoping it is the MTM. Everything I have read about the Superchip is not that super.
Have a great night.
Thanks again
Thread Thread Starter Forum Replies Last Post
Intermittent boost jack225hills 1.8T Discussion 0 09-07-2015 04:05 PM
86 5k tqcs no start after heavy rains PoisonBeef Audi 5000 / 200 / V8 Discussion 1 09-04-2015 06:29 AM
overboosting tvelasquez1 2.0T FSI Discussion 0 09-01-2015 08:35 PM
New Member and New Owner of 95 Cabriolet. stormchaser1967 New Member Welcome Area 0 09-01-2015 02:29 PM
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
What's your question?
Send
