Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
1995 S6 Brakes
Old 05-04-2006, 08:59 AM
Roadhound's Avatar
Default 1995 S6 Brakes
What can I do to improve the brakes on my 1995 S6?
Old 05-04-2006, 09:50 AM
Hoog23's Avatar
Default Go BigRed...but
Seriously all you may really need is a new brake job on all four corners.
I found that my rear calipers were frozen and not really doing much to help stop the car. After four new rotors and new brake pads the car feels like a different animal. Although I don't track the car or anything. If I was smart enough I would have just replaced the rear calipers with new ones since I probably paid my mechanic practically as much to get them un-frozen.
I do have a set up porsche calipers and A8 rotors that I hope to install at some point this summer. If you do a search you will find loads of info on the different porsche caliper based upgrades.
Old 05-04-2006, 10:27 AM
TabulaRasa's Avatar
Default I don't think big brakes are needed unless you track.
I didn't get any brake fade in my 20 min sessions at MAM. Going to BIR in a little over a month, we'll see how they hold up.
I could use more clamping force however. Even upgraded to basically the maximum extent, my G60's had a hard time dipping into ABS in a straight line with my 255 tires. Can easily do it with 225's though.
Old 05-04-2006, 10:48 AM
Roadhound's Avatar
Default Re: I don't think big brakes are needed unless you track.
I just got the car and intent to track it but 99% street as daily driver. Thanks for the info. Any brand name preference?
Old 05-04-2006, 11:00 AM
SilberUrS6's Avatar
Default Disagree.
I consider the stock brakes disappointing. They are certainly adequate for street use, but nothing more than that.
If you plan on driving even a little bit into the "spirited" side of things, I think larger brakes are necessary.
Then again, I'm a big fan of "whoa, there!"
Old 05-04-2006, 11:10 AM
germantoy's Avatar
one of the biggest complaints about the car was the stock brakes now its pissa
Old 05-04-2006, 11:24 AM
TabulaRasa's Avatar
Default Re: Disagree.
I'm running even with B6 S4's equipped with Carbotech Panthers through the corners. And I didn't get brake fade.
B6's have more pull than me on the straights though.
I will get upgraded brakes eventually, I just don't want to have them as a crutch for inexperienced driving at this point. I feel I am still braking too early and harder than I have to right now.
In just over a month I'll be headed to my 3rd ACNA event of the year.
Old 05-04-2006, 01:05 PM
SilberUrS6's Avatar
Default Yeah, the B5 cars have better brakes...
...from the factory. The C4 cars really are only adequate - there is a huge difference in stock brakes, IMO.
Old 05-04-2006, 04:32 PM
UR-Idiot Savant-S6's Avatar
Default Do this to them.
<center><img src="http://pictureposter.audiworld.com/19204/image017.jpg"></center><p>
Old 05-04-2006, 04:34 PM
SilberUrS6's Avatar
Default Slotted A8L rotors?
323x30?
Plated?
Where'dya get 'em?
Quick Reply: 1995 S6 Brakes
