Rpm hunting / surging - AudiWorld Forums
Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Old 12-24-2011, 02:48 PM   #1
Default Rpm hunting / surging
Hello Audi Folk. I wanted to know if Rpm surge or hunting is normal on these cars. When I am in neutral and trying to hold the RPM's at say 3,000 steady I find it surges and falls cycling up and down by as much as a 1,000 when cold in closed and less when warm. I've never had a car do this but this is my first turbo. Any thoughts? It idles fine with very little variation. Seems to be a closed loop problem. I understand that the o2 sensor maybe getting a rich or lean reading and the computer is compensating back and forth. Is there a common known issue related to this?
TeamO is offline   Reply With Quote
Old 12-24-2011, 05:58 PM   #2
UrS4boy's Avatar
Why are you trying to "idle" at 3000 RPM? You are asking the ECU to do something that doesn't make sense.
Idle = 800 to 1000 RPM and is controlled by a properly functioning idle stabilization valve (ISV), as controlled by the ECU.
Here is some N71 ISV reading for you (Click on the link and then the N71 label in the upper right(ish) corner of the diagram):
Click Here
UrS4boy is offline   Reply With Quote
Old 12-25-2011, 10:20 PM   #3
I had surging just like this, and it was my Oxygen Senson.
Mine was the original with 115k miles on it. if you don't know when yours was last replace I would start with replacing that.
(PS: urs4boy, holding RPMs can be used in emissions tests, that's how i found out my car was surging)
sk88erguy is offline   Reply With Quote
Old 12-26-2011, 03:48 PM   #4
o2 sensor looks new. I know that doesn't mean it works so I'll check that out it sounds logical. Thanks for the reply.
Old 12-26-2011, 04:02 PM   #5
I noticed it when I was starting up on a cold morning. Trying to get heat to melt frost. In open loop it held rpm fine then in closed loop it would pulse up and down when I tried to hold it at a steady rpm over 1,000. I have had many coil issues before installing a used Apikol set up. I wonder if all the missing could have damaged the o2 sensor. I want to get new oe plugs and get a set of the latest 1.8t coils so that I know all of that system is solid. Are the "D's" the latest revision? It idles just fine. Thanks for the layout diagram. I cleaned out the ISV just as a general maintenance thing but no difference was noticed.
Old 12-26-2011, 04:32 PM   #6
UrS4boy's Avatar
If you are going to buy new "1.8t" style coils, buy the newer 2.0L TFSI coils. Same harness connectors as the 1.8t coils but supposedly with better resistance to dwell-induced self-heating failures.
Old 12-26-2011, 04:58 PM   #7
Thanks for the tip on the coils that's just the kind of wisdom I've come to expect from from you. Appreciated. Any ideas on the o2 sensor? I bet you think: new plugs and coils first then go from there Could the TPS cause hunting? or the MAF? Funny thing is this car passed CA smog with no problem. It does drink a lot of gas but I can't tell if that's my ADDICTION to boost or if that's just what it is. I think I get around 16-18 mpg mixed driving. Was hoping to see 23 on the highway but haven't done a trip to check.
Old 12-26-2011, 05:39 PM   #8
UrS4boy's Avatar
"Drinks a lot of gas" = sounds like an O2 sensor problem. Have a read on this:
http://forums.quattroworld.com/s4s6/msgs/21012.phtml
Old 01-09-2012, 03:35 PM   #9
New coils new plugs and o2 sensor. Running better than ever until I spotted the coolant tank leak. Of course I tried to tighten the clamp and it cracked. Always something. O well I planned on replacing it anyway. I'll let you know if MPG improve after a tank of gas. Thanks again for the help all.
Old 01-09-2012, 11:15 PM   #10
GoHeels's Avatar
Nice. I believe my MPG went up 1-2 mpg with my LS2 coil kit.
That coolant piece is known to crack after 10+ years. Not to hard to replace it.
GoHeels is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
:: ECS Tuning :: NEW!! B8 S4 ECS Performance Lightweight Flywheel ECS Tuning-Audi S4 (B8 Platform) Discussion 2 03-27-2016 07:49 AM
:: ECS Tuning :: NEW!! B8 S5 3.0T ECS Performance Lightweight Flywheel ECS Tuning-Audi Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 3 02-04-2016 09:36 AM
Transmission Issues Hours of Service New Member Welcome Area 1 11-03-2015 09:35 AM
Help with 2005 Audi A6-3.2L quattro BKH bballfreak A6 / S6 (C6 Platform) Discussion 4 10-12-2015 06:14 PM
AWE Tuning Lead Times: 8V S3 Josh/AWE Audi A3 / S3 /RS 3 MKII 2 10-01-2015 11:37 AM
Tags
20, 2000, audi, hold, hunting, issue, neutral, rpm, s8, smog, surging, test
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
