Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
S6 CUTS OUT ABRUPTLY AT WIDE OPEN THROTTLE
Old 10-18-2015, 06:32 AM
  #11
UrS4boy's Avatar
Originally Posted by Boston Tom
I don't believe it is a boost leak. It appears to be the ECU. If I stop, shut off & re-start the car it is fine. Thanks, Tom
Tom: Sorry but with that attitude, there is no reason to ask your question here. You apparently know the answer already. LOL.
However, did you know that when the Michelin Man cross-over to intercooler hose split opens up and dumps a massive amount of air, the ECU freaks out and goes into limp mode? Turning the key off and on likely resets the ECU back to non-limp mode and the process starts over again.
But please, persist in ignoring good advice and DO NOT check for boost leaks.
Old 10-18-2015, 07:17 AM
  #12
moorewr's Avatar
Originally Posted by yodasfro
A large leak you should be able to hear, smaller leaks will tend to over spin the turbo and you'll hear it whining. Your squeak may be a bad BPV pull it out and test it.
Thanks for the advice!
Old 10-19-2015, 09:15 AM
  #13
Boston Tom's Avatar
First thought was leaks, but I can't find any.
My ECU is acting oddly, but just on occasion. I got 20-30 ok runs between ECU failures--boosting perfect (I have a gauge)--overboost works fine.
When it goes into this mode, it shuts off as in ignition shut off when I floor it.
At part-throttle runs normal.
But when I re-start it it is fine & no boost loss--runs great.
It also occasionally goes to a 2100 RPM "idle" when I start it. Again if I re-start, it is normal again.
I am in the mode of waiting for these faults to become more regular.
Old 10-19-2015, 09:37 AM
  #14
UrS4boy's Avatar
IF you haven't done a proper boost leak test as per my Boost Leak Post, i.e. complete intake and PCV system under say 15-20 psig, with soapy water, I remain skeptical that you don't have a boost leak.
Sorry. Good luck.
LaserSVT
11-26-2015 11:34 AM
urojohn
S4 (B8 Platform) Discussion
11-01-2015 04:02 PM
Phil G.
TT (Mk2) Discussion
16
10-29-2015 08:05 AM
Devinv
09-15-2015 11:47 AM
03_AR_CO
09-13-2015 05:15 PM
Quick Reply: S6 CUTS OUT ABRUPTLY AT WIDE OPEN THROTTLE
