urS4 engine stopping problem
Hi, I have an S4 sedan 91' i've had it for one year now and I got plans to get it in very good condition, and as original as possible. but i got a problem with it, in the beginning of the ownership it stopped every time i took a hard right turn or got enough G force in it. I could drive as slow as 10km/t. but now it also stops when i'm turning left, and it need less ''G force'' now then in the beginning. I haven't found anyone here i Norway with similar problem, so i'm trying my luck here
You obviously have a seriously loose connection somewhere, e.g. the engine ground strap under the turbo area, or the grounds that are connected to the cam cover and intake manifold or there is a connection or fuse issue at the ECU (in the passenger footwell area).
Likely an easy fix - once you find it.
19khz
11
02-26-2010 08:13 AM
Rankster
04-12-2004 08:26 AM
