Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
light throttle ping ? can I log it ? measuring block ?
Old 10-30-2008, 10:39 AM
marvgomez's Avatar
Default light throttle ping ? can I log it ? measuring block ?
I've got a new noise (well, it's been doing it a while but I'm getting paranoid) It almost sounds like a slight ping but only when lightly applying throttle and early in the rpm range (it normally doesn't ping at WOT, unless I have a bad batch of gas)
I'd like to log the knock sensors just to see what they're hearing when I go through the eppisode. anyone know the measuring block ?
Old 10-30-2008, 10:57 AM
ThetaTau87's Avatar
Is it at high load and low RPM? That could be knock.
Old 10-30-2008, 11:17 AM
marvgomez's Avatar
nope. light load. just kind of feathering the gas.
Old 10-30-2008, 12:03 PM
ThetaTau87's Avatar
Default The load I'm refering to is not related to throttle position. You can have high load at low throttle
Such as if tip into the throttle slightly on an uphill grade or starting off from a stoplight. Light throttle at high load and low RPM are good conditions for knock.
Old 10-31-2008, 05:11 PM
marvgomez's Avatar
no help here ?
man_utd_4eva_727@hotmail.co.uk
11-22-2016 01:05 PM
Craigito
11-08-2008 08:35 PM
KYNZ
04-29-2007 06:46 AM
Mitch S6 Avant
11-28-2005 06:38 PM
Captain Sheetmetal
12
10-06-2004 03:26 AM
Quick Reply: light throttle ping ? can I log it ? measuring block ?
