Where is the other end of this hose - AudiWorld Forums
Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Old 07-31-2014, 06:29 PM   #1
Default Where is the other end of this hose
Took my car for smog it passed but now this hose is missing and my car smells like gas?
BB1995S6 is offline   Reply With Quote
Old 07-31-2014, 08:00 PM   #2
UrS4boy's Avatar
Don't know why you are smelling gas but it has nothing to do with that hose barb on the wastegate cap. There never was a hose there on an AAN in an UrS4/S6.
UrS4boy is offline   Reply With Quote
Old 08-01-2014, 05:42 AM   #3
Mine hade one there yesterday
Old 08-01-2014, 07:11 AM   #4
UrS4boy's Avatar
Quote:
Sorry but I have to laugh.
It has been known in the past that sometimes stupid/unknowing people doing CARB/smog/MOT tests have failed an UrS4 or UrS6 AAN because "There is a hose missing on the wastegate cap". Arguments that there never ever was a hose there on the AAN fell on deaf ears. The solution was to put a hose on there and run it somewhere where the end couldn't be seen and then take it to another shop for retesting. Typically the car then passed the tests.
In your case, I suspect the shop doing the test knew that that hose was complete BS and removed it for you. Trust me, your car left the factory without a hose. You're fine in that regard.
As for fuel smell, there was a recall on one of the fuel lines feeding the fuel filter years ago and the full line feeding the fuel rail has been known to fail at the joint. Look/touch/smell in those areas.
Old 08-01-2014, 05:36 PM   #5
Come to find out I'm not crazy it was there but my smog tech took it off because it was vented to air? And the car never had one. You were right I did not need it so it's outa here. The fuel leak was a hose that runs into the fender had a crack in it ? I think it's a smog vapor thing?
On a side note on the way back from smog yesterday the car started to have a misfire under load it has been doing it for a while.the previous owner has swapped over to the spare Chanel of the pos already so that was out of the question so I pit on this.......
Old 08-01-2014, 05:38 PM   #6
Boy I must have had a problem with low spark output? Because the car starts sooner .....les cranking and idles smother runs smother too..... I'm happy and so is my old girl
Thanks again for your help...
Thread Thread Starter Forum Replies Last Post
My first Audi! A8L 4.0T......beastly I tell ya! PainDOC A8 / S8 (D4 Platform) Discussion 10 06-11-2016 11:48 AM
October 25th Sunday - Touge.ca Shannonville Full track event 11:30-5:30pm #23 Event!! Touge.ca Canadian Discussion 1 10-18-2015 07:18 AM
Transmission Failure jonedwd Audi A3 / S3 /RS 3 MKII 2 09-26-2015 10:49 PM
My first Audi! A8L 4.0T......beastly I tell ya! PainDOC A8 / S8 (D4 Platform) Discussion 0 09-26-2015 07:32 AM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
