oil
Have you checked you Owner's Manual for the oil recommendation? If you are in the USA, some of the cars got a Castrol 10W60 while others used the pedestrian VAG spec 502.00.
Does the car have a dry sump?
Be sure to follow the service manual procedure. These dry sump engines require more than a drain plug or two and filter replacement. Quite a bit more. There is a youtube video but the manual is mandatory for your exact model & engine.
CT04S4
12-05-2004 06:55 AM
GTEJR
11-14-2002 10:30 AM
