A4 B7 Sub Replacement for Non-Bose - AudiWorld Forums
Old 04-20-2010, 04:49 PM   #1
Default A4 B7 Sub Replacement for Non-Bose
I recently came accross this thread that details on how to replace the existing sub woofer on a B7 A4:
http://www.audizine.com/forum/showth...ock-sub-woofer
I have a non-bose system with an RNS-E (originally a Symphony II) and I wanted to know if it was possible to replace the existing sub with something like a Pioneer TS-SW841D without installing a new amp (essentially using the same wiring that is already driving the current sub). I'm somewhat new to car audio upgrades, so I apologize in advance if this is a dumb question.
Thanks!
jga85 is offline   Reply With Quote
Old 05-02-2010, 02:41 AM   #2
No such thing as a dumb question!
If you know the power output of the stock amp, I could help you out.
Cheers!
marcus.sharks is offline   Reply With Quote
Old 05-04-2010, 04:55 PM   #3
VP Electricity's Avatar
Not really. The factory sub is getting very little power and is mounted in an infinite baffle rear-deck application (if you have a sedan - if you have a wagon, you have a plastic ported enclosure in the rear side panel).
There aren't many woofers that work well infinite baffle, and none will work off of that amp. It's too puny.
The signal coming out of the RNS-E is actually filtered- as you increase the volume the bass is removed to keep that factory system from coming apart. When upgrading it, we insert a grounded wire into the empty "Bose pin" slot in the RNS-E connector, to force the OEM HU to stop activelly filtering the bass out at higher volumes.
You probably can't get the minor improvement you're looking for easily.
Personally, I'd rather have a 2-channel amp and a good 6 and tweeter in front, with the Bose pin stuffed, and leave the factory woofer unplugged.
VP Electricity is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
When to replace shocks and struts - Wobble at 20mph/40mph ZPA117 A4 (B8 Platform) Discussion 4 09-08-2015 12:55 PM
Transmission slipping after replacing fluid Jorge Vargas A4 (B6 Platform) Discussion 4 09-08-2015 08:45 AM
Coolant temperature sensor 97 audi cabriolet location and replace 9552T500 Audi 90 / 80 / Coupe quattro / Cabriolet 3 09-08-2015 06:41 AM
2007 A3 Front Right Axle HELP marshap1 Wheels & Tires Discussion 0 09-06-2015 01:21 PM
Please help! Audi TT MK2 2008 - Possible Vacuum Pump Leak - MIL ON FedericoDC 2.0T FSI Discussion 0 09-05-2015 12:45 PM
Tags
a4, amp, audi, b7, bose, factory, location, rear, removal, replacement, rs4, stock, subwoofer, upgrade, wagon
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
