Sponsored by:
Sponsored by:
audi a6 2002 radio FM not tuning into stations :(
Old 02-06-2008, 12:00 PM
jcmuse's Avatar
Default audi a6 2002 radio FM not tuning into stations :(
i had a sat radio installed recently. when i got the car back i found that FM radio won't seek to stations. It just cycles through all the frequencies as if there is no signal. manually tuning works. not sure if there is a setting i can change to fix this or do i need to take it back.
Old 02-06-2008, 12:29 PM
Reggie's Avatar
Default souonds like they did not connect the FM antenna correctly
<center><img src="http://pictureposter.audiworld.com/102/audi_radiio.jpg"></center><p>In the A4s there is a antenna amp (#3) in the back - not sure about the A6s
Old 02-06-2008, 10:18 PM
5speed6  v.2's Avatar
Default Take it back to the place that did the install...
..sounds like they did a direct connect, and interrupted your antenna signal line.
Old 02-17-2008, 12:28 AM
diagnosticator1's Avatar
Default What SAT system? ....
If it's not the OE Audi SAT, but uses a FM modulated signal inserted in to the HU via the FM antenna, where you need to tune FM to a frequency like 89.1mhz, to listen to SAT, then the FM modulation adapter used, must be interfering with normal FM signal strength.
The HU won't scan FM stations that the signal strength level is below some arbitrary value, therefore, the failure to stop at any FM stations at all, means the signal strength for all FM stations is below the signal strength needed to stop on a station.
Take the install back to the shop and complain.
SED8R
12-11-2018 05:03 PM
US_A6_to_EU
6
10-24-2010 10:07 PM
ofer_iz
10-08-2009 05:36 AM
broncoupe
09-06-2005 09:28 AM
mallam
6
08-31-2005 06:33 AM
Quick Reply: audi a6 2002 radio FM not tuning into stations :(
