Engines goes off - AudiWorld Forums
Engines goes off
Old 06-08-2014, 10:37 PM   #1
Default Engines goes off
I have the 3.0 a4 cabriolet. Unfortunately lately engine goes off wen a circle with a triangle in the middle appears on my dash. Sometime after parking for a while it stop. Pe I have to take of terminals for a while for that fault to go. What could the problem be? I have had to change fuel pump n airflow meter. I'm in Ghana.
Saka is offline   Reply With Quote
Old 06-12-2014, 12:40 PM   #2
AudiWorld Expert
Reggie's Avatar
Quote:
You probably should get a Ross tech VAG-COM
http://www.ross-tech.com/
You also might want to post this in the correct forum for the model car you have
Reggie is offline   Reply With Quote
Old 06-18-2014, 04:31 AM   #3
Did you try to diagnose your car from a scanner? did you find any codes? Try check the coil or electrical lines going to spark plugs or check the air intake connections if it is clogged or it could be a vacuum leaks.
joaquinnparker is offline   Reply With Quote
Old 06-18-2014, 04:50 AM   #4
sbarlas's Avatar
Are you sure it's no the stop start that's kicking in ? If so you'd see this on the dash :
However, the only other circle with a triangle in the middle warning light I know of is this :
And this indicates an ESP fault.
sbarlas is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
:: ECS Tuning :: NEW!! B8 A4 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi A4 (B8 Platform) Discussion 14 12-23-2016 04:46 AM
S3 engine in other Audis? myroad Audi A3 / S3 /RS 3 MKII 10 09-17-2015 07:41 PM
Exhaust and Engine Breakdown leds giuseppepat Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-02-2015 03:47 AM
:: ECS Tuning :: NEW!! B7 A4 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi A4 (B7 Platform) Discussion 0 09-01-2015 10:16 AM
:: ECS Tuning :: NEW!! B8 A5 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-01-2015 09:27 AM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
