Sponsored by:
Sponsored by:
Engines goes off
Old 06-08-2014, 09:37 PM
Saka's Avatar
Default Engines goes off
I have the 3.0 a4 cabriolet. Unfortunately lately engine goes off wen a circle with a triangle in the middle appears on my dash. Sometime after parking for a while it stop. Pe I have to take of terminals for a while for that fault to go. What could the problem be? I have had to change fuel pump n airflow meter. I'm in Ghana.
Old 06-12-2014, 11:40 AM
AudiWorld Expert
Reggie's Avatar
You probably should get a Ross tech VAG-COM
http://www.ross-tech.com/
You also might want to post this in the correct forum for the model car you have
Old 06-18-2014, 03:31 AM
joaquinnparker's Avatar
Did you try to diagnose your car from a scanner? did you find any codes? Try check the coil or electrical lines going to spark plugs or check the air intake connections if it is clogged or it could be a vacuum leaks.
Old 06-18-2014, 03:50 AM
sbarlas's Avatar
Are you sure it's no the stop start that's kicking in ? If so you'd see this on the dash :
However, the only other circle with a triangle in the middle warning light I know of is this :
And this indicates an ESP fault.
audipnw
10-07-2015 08:50 AM
GMIBMan
TDI Discussion
05-06-2012 03:18 AM
SimplyANovice
04-18-2011 09:29 AM
AAACGT
03-06-2006 03:24 AM
87Audi
28
11-09-2004 01:03 PM
Quick Reply: Engines goes off
