Q5 MMI CD Stuck
Q5 MMI CD Stuck
Audi Q% 2012 model. I have MMI DVD/CD player with two SD slots below.
This morning my CD got stuck in the CD player. The player is making noises as it would try to eject something but it does not do anything. The CD does not go out neither goes back into the playing position thus I have no playable medium inserted message displayed.
Any solution to this problem?
Frank
Frank
I actually found solution. I found it on YouTube. I used the sturdy piece of thin long plastic (maybe 1 inch wide and 8 inch long). I place the sticky tape on plastic with sticky part on outside and secure it to the plastic at the edges.
Then I put the plastic into CD player gap, pushed eject button and managed to grab the CD with the sticky tape and pulled it out.
If you want to try it, make sure that your sticky tape is taped on the sides of plastic so it is does not get undone. Otherwise you may leave the sticky tape inside of the CD player.
audifirst
11-19-2006 03:06 AM
GusS
01-04-2000 05:53 AM
