Auto Detailing Discussion Discussion forum for the in's and out's of properly detailing your ride
chrome exhaust tip sealing
Old 02-23-2015, 07:06 AM
bobby$m's Avatar
Default chrome exhaust tip sealing
I have fiund a way to clean my chrome tips using 0000 steel wool. However, even after 100 miles they are dirt again. What is the best way to "seal" the chrome to allow for longer time between cleaning. Does "Rejex" work?
Old 02-23-2015, 07:39 AM
uberwgn's Avatar
Bobby, I've tried a bunch of products on our cars including a "high temp" sealant. They all help but I've found that frequent cleaning, probably every week, is required if you want to keep them looking their best.
Personally, I've been using Chemical Guys' metal polish and find that works a bit better than the eighteen other metal polishes I have. Good stuff. The other idea I can share would be to try one of the permanent coatings. I think someone has made one for brake calipers. These coatings will be at their best when applied to a perfect (new) surface.
During my weekly wash, I mist a little bit of my wheel cleaner on the exhaust tips and let it dwell for a couple of minutes. I go back with a sponge and can remove some of the hardened black deposit. I polish with Chem Guys about 1x/month, weather-permitting. You will find or have already discovered that aggressive cleaning ends up dulling and compromising the chrome finish.
Old 03-04-2015, 03:35 AM
pjsean5's Avatar
Try using sealant like the Opti coat after using metal polish.
Old 08-12-2015, 06:03 PM
DavidA's Avatar
my history- used 0000 steel wool with Tarminator (it went off the marrket for a while), it had to be "re formulated" according to EPA rules. ...that did the trick.
While it was unavailable I used WD40 with 0000. Now its being sold at AutoZone $7 / don't know if its as effective as before. It got rid of the carbon build up after a few cleanings over a period of time 2-3 weeks...
Old 09-22-2015, 09:00 AM
uberwgn's Avatar
P21S Polishing Soap is another very good product for this task when used frequently.
Old 09-22-2015, 09:19 AM
tenspeed's Avatar
I haven't heard of the polishing soap before but I use "Soft Soap" on all sorts of tough cleaning tasks. Find it in with household cleaning products at the grocery store. Claims not to scratch.
As for sealing the polished chrome, I too would try one of the sealing products such as Opti-coat. I have heard that it makes for easier clean up on wheels.
Old 09-22-2015, 09:36 AM
uberwgn's Avatar
Yeah, the Polishing Soap is new to me too. Just got my first container earlier this year and it's almost gone! You simply scrub a bit with the coarse sponge they provide and rinse. That's it. Subsequent use leaves a near-perfect surface. I think it's the best new product I've tried this year.
Old 09-22-2015, 12:38 PM
arn560's Avatar
"Simple Green" on a scrubbing pad and rinse off!
Old 09-22-2015, 12:44 PM
uberwgn's Avatar
Arn, I've tried that. No comparison.
Old 08-14-2016, 05:10 PM
Garycw's Avatar
I cleaned mine with steel wool also. However I'll be trying fireplace glass door cleaner next time to check the results. It removes the soot from glass that nothing else will
Quick Reply: chrome exhaust tip sealing
