Brakes Discussion Discussion forum regarding brake tuning, upgrades and questions
2004 Audi A8L brake warning lights and beeps...please help
Old 04-13-2016, 01:04 AM
Ronda69's Avatar
Default 2004 Audi A8L brake warning lights and beeps...please help
I am a single mother who could really use the help of other Audi owners and from reading posts here I think I'm in the right place.
I just bought a 2004 A8L with 120k miles from a pvt party seller. The seller owned a basic auto shop where he employees basic mechanics to do brake and oil changes sort of thing. I drove the car home to La (about 300 miles) and that night when my brother took the car out it started to make a beeping noise that seems to be related to parking brake whenever the car stops at a signal which it doesn't make o. The freeway. The previous owner said that he changed the rear brakes but that they needed dealer calibration when I noticed both the ABS and traction warning lights on during test drive. It didn't make the beeping sound at time of test drive.
I have pretty much determined that the last owner is somewhat of a liar. He got the car at auction and I'm guessing got in over his head with what his shop is capable of and he really didn't need the car so he just needed to unload it...which I'm cool with.....but, I just need to know how to trouble shoot this. I have the following info....
He changed rear brakes with what he claims to be dealer OEM pads using a scanner. He claims he was unable to calibrate because he didn't have the special tool to do so. He further claims that the lights and beeping started after he did this....and, that the beeping was random. The Abs light on, traction light on, parking light on, and now beeping when I stop at signals.
I do have a brother and uncle who are great mechanics but neither are really experienced with German cars....and, honestly they can end up costing me more money in the long run by buying diagnostic equipment that I don't need or by playing the quessing game only to replace parts that don't solve problems and only leave me and my 9 yr old autistic daughter stranded on a LA freeway somewhere when they are nowhere around. Bless their hearts as they mean well.
Can someone please advice me so that I can advice my family mechanics without offending them or at least walk into a local mechanic or dealership with enough information so as to not get completely screwed.
Thanks Ronda
Old 04-15-2016, 09:37 PM
MP4.2+6.0's Avatar
Hi. Came across this by chance. You should really post it on the Audi D3 A8 board where you will get a variety of experienced help.
Meantime, reading your description, a guess is whoever worked on it really did not know what they were doing and may have damaged some parts, unfortunately which may be expensive if it is not just getting it calibrated electronically. You need either dealer equipment or a VAG COM/VCDS software tool to open and close the rear brakes correctly. A good independent shop specializing in Audis and VWs should have it. Joe's Garage and Fly by Night Mechanic who works on Ford pickups and Taurus's probably won't. If they tried to do it by either taking the parking brake motor off or simply forcing it mechanically the way older Audi brakes used to work, they probably damaged it mechanically.
Net, you are going to need a qualified mechanic to look at it if you or family don't have the skills or the computer tool. To be clear, it is NOT just a generic code reader many mechanics or individuals may have. Find an independent shop who works on Audis and VWs and you should be in better hands. Fortunately rear Audi brakes are now pretty generic and similar. Most late model Audis from the mid and late millennium to newer will have similar rear brakes with the motor driven parking brake set up like your A8.
luigi33dayco
07-21-2016 06:31 AM
Ronda69
04-13-2016 09:26 AM
Tekwon-V
06-23-2004 06:12 PM
SmokeyA4turbod@ebay
07-06-2003 12:44 PM
Quick Reply: 2004 Audi A8L brake warning lights and beeps...please help
