Brakes Discussion Discussion forum regarding brake tuning, upgrades and questions
Audi Q7 2007 3.0TDI Brake Padle sinking to floor
Old 01-30-2017, 09:19 PM
AnkitSaini's Avatar
Default Audi Q7 2007 3.0TDI Brake Padle sinking to floor
Hi Gurus,
I have a Q7 2007 3.0TDI UK import in New Zealand. My car brake padle sinks to the floor after driving around 120km. Happened twice, If i keep driving another 200km the brake doesn't workand Paddle goes all the way to floor.
Took it to mechanic , No Oil leak, Master cylinder replaced with second hand one, Brake servo tested and OK. No hot disc after padle sink , Brake pad are in good condition, Can't see any piston seize from outside. what the hack ...
I have only noticed the rear discs are bit low and may need replacement but that shouldn't let Brake padle to sink to the floor after 2 hour drive ?
Paddle comes back to normal after normal bleeding procedure and stay fine if I drive this car locally or don't go too far more than 100km.
Can someone please help !
Regards,
Ankit
Old 02-02-2017, 06:56 AM
J. Patterson's Avatar
Originally Posted by AnkitSaini
Hi Gurus,
Regards Ankit
This IS an odd malfunction. One thing I WOULD suggest is that your mechanic check your wheel bearings for excess play. Excess play can allow runout of the rotor which pushes the pads back away from it. This will result in excessive pedal travel. Read up on "pad knock back"
Pad Knockback
Old 02-02-2017, 12:04 PM
AnkitSaini's Avatar
Thanks mate, I will take my car to mechanic today and get that checked..
AF1
A4 (B7 Platform) Discussion
08-08-2011 05:52 AM
fanginc
06-24-2009 11:11 AM
deans a3
Audi A3 / S3 / RS 3
05-25-2009 10:50 AM
gk1
A4 (B8 Platform) Discussion
17
07-21-2008 10:04 AM
Quick Reply: Audi Q7 2007 3.0TDI Brake Padle sinking to floor
