Carbon brake cooling mod
Hi guys, I just wanted to show you what I've been up to lately. I've made an carbon air scoop to provide the brakes with more air so they will be cooled better. Mainly the RS3 has this problem, but also the TTRS doesn't have the most perfect OEM brakes (understatement).
In the pictures below you can see what I made for my TTRS. Basically it will fit any RS model and any car with NACA ducts but I designed it on my TTRS.
This mod should prevent brake fluid boiling, pedal fade and drastically reduce pad and rotor wear and occurence of rotor warpage.
The product is 1mm thick and 15mm in height so that there will be no issues with lowered cars and speed bumps. The shape is from wide to small which creates a vortex effect forcing even more air going to the brakes.
Attachment 103229
Attachment 103230
Attachment 103231
Attachment 103232
Attachment 103233
Attachment 103234
Attachment 103235
Not much later a measurement was done with a heat camera. The right front wheel had a carbon air scoop and the left front wheel didn't.
Two times a emergency brake test was done from 150 km/h to 10 km/h then the car was brought up to 130km/h and for 4 times the car was slowed down to 80km/h in a short period of time.
After this the car was driven for a short while after which the brake temperature was measured.
Conclusion: improvement of 23,6%.
Soon I will repeat this experiment with GiroDisc breaks on my car as I will receive them in a couple of days.
P.S Abovementioned taken into account that the right front rotor will always be hotter as the left one as Audi only produced one kind of rotor (for left and right) so actually the right rotor is going in the wrong direction.
Attachment 103236
Basically the NACA ducts get enlarged so that more air is being forced to the brakes.
Simulations also have been done which show that a traditional scoop will get almost twice as much air moved then a NACA duct.
Attachment 103229
Attachment 103230
Attachment 103231
Attachment 103232
Attachment 103233
Attachment 103234
Attachment 103235
Attachment 103236
Above a bit more science behind this brake scoop I've developed.
A traditional scoop will get 0,98kg/s in this simulation while the NACA duct by itself gets 0,46kg/s.
A traditional scoop gets almost twice the amount of air replacement.
MP4.2+6.0
Q5/SQ5 MKI (8R) Discussion
03-28-2022 08:04 PM
Sia Bani
12
09-25-2003 07:12 AM
