TT MK2 Please help me with rear brake rotors - AudiWorld Forums
Brakes Discussion Discussion forum regarding brake tuning, upgrades and questions
Old 01-27-2013, 07:52 PM   #1
Default TT MK2 Please help me with rear brake rotors
I was working on the brakes. Front two were easy... but the rear ones are causing some headaches, and I was wondering if I could ask for some help.
Got everything off, pads, caliper.. but the rotor is stuck and I cannot seem to remove it without removing the caliper carrier. From previous experience, I did not have to remove the carrier but I cannot seem to get it off. And to get the carrier removed, I was not sure which tool to get. So I wanted to ask you for some help... Does anyone know how to do it?
I have some pictures to show what is happening here..
I think that is the 12 point screw or something. Or can I use Torx to remove the one between the spring? Does anyone know?
It gets caught like this
If you could please help me, I would really appreciate it!
Thanks,
Jae
jh880428 is offline   Reply With Quote
Old 01-30-2013, 10:13 AM   #2
I don't have a TT, but on every Audi i've ever owned, i have to remove the carrier to get the rotors off. Easy to take off, generally two bolts, some hex, some allen.
You also may need to tap it if it is rusted to the hub.
Finally, you need a piston tool that locks into the holes int eh piston, and applies (lots of) pressure while it turns the piston to screw it back in. Thee can be purchased from harbor freight in a kit that will handle pretty much any car.
Grant
Just Me is offline   Reply With Quote
Old 02-08-2013, 03:31 PM   #3
Anyone there? Am i typing int he dark?
Old 02-12-2013, 08:51 AM   #4
Grant,
THanks for the reply...
So you are correct, I had to remove the caliper carrier but I was not sure what tool to use. But I did end up finding it and it was triple square tool. More teeth then just regular hex.
Also, for my B7 A4, I did not have to move the carrier so that is why i tried it that way.
Thanks for your reply and I really appreciate your help!
Jae
Old 02-12-2013, 02:49 PM   #5
glad it all worked out!
Triple square eh? They just keep adding stuff to keep us out i guess.
Grant
Thread Thread Starter Forum Replies Last Post
Brakes: Cost Pads Rotors ebod0000 A6 (C7 Platform) Discussion 137 02-19-2017 06:38 PM
Audi A6 FS: 370mm Alcon / Stasis Front Big Brake Kit! Allroad BBK N'Syncro Parts For Sale 12 01-24-2017 04:46 PM
Audi A4 2002 S4 6spd 98k rsixxer23 Vehicles For Sale 4 01-06-2016 04:25 AM
Best way to launch my RS6? LaserSVT RS 6 Discussion 2 09-06-2015 08:54 PM
Can 00604 - Potentiometer Positioning Motor for Air Flow Flap cause no heat? ajg617 A6 / S6 (C5 Platform) Discussion 0 09-06-2015 08:23 AM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
