"If" someone was looking for an audi TT, I may know
<center><img src="http://pictureposter.audiworld.com/78733/tt_at_bbq.jpg"></center><p>one looking for a new home.
2000, TT coupe, 82ish k km's.
The factory stuff:
Quattro
xenon lights
1.8 T engine
Original control arms (Audi will replace at their cost if you want the new arms)
Un-spoiled (Audi will add spoiler at their cost also)
The aftermarket stuff:
18" Spyn rims w/sumitomo tires, about 3k on them
Brembo cross drilled rotors w/ pbr pads, about 3 k on them also
Stainless steel brake lines in fronts
VTDA cold air intake
APR chipped ECU
19mm neuspeed rear swaybar
Koni adjustable shocks
Eibach springs
Borla cat back exhaust
3.2 rear valance
Tinted tailights and windows
Kenwood in dash cd/mp3 with kenwood music keg
Soundstream subs, amp and crossover in trunk
Winter tires with rims, and original 6 spoke TT rims will also come with the car.
Other parts to come with car are the original exhaust, valance, rear swaybar and airbox.
Picture is of car on June 9th, 2008.
The factory stuff:
Quattro
xenon lights
1.8 T engine
APR chipped ECU
Eibach springs
3.2 rear valance
noob question. What is the difference in the engine that makes the 225 vs 180HP?
Is it K04 vs K03?
If so, is yours the 225 or 180? I see dual exhaust which was the visual clue of 225, but since you have a Borla, I'm wondering if you were 180 and went with a dual aftermarket.
Make sense?
Make sense?
I believe it is the engine angle. I'm a 180hp plus chip
but you are correct, usually the single outlet denotes a 180 or FWD I think.
Maallish or Auditt123 may know more on this, seeing how they have the 225's.
Two intercoolers, not turbos...
Mechanically, the TT uses a transversely mounted engine with front or quattro four-wheel drive. It was first available with a 1.8 L turbocharged inline four cylinder 20-valve engine, with either 180 PS (132 kW) or 225 PS (165 kW). The engines share the same basic design but the 225 PS version features a larger turbocharger, an additional intercooler on the driver's side, forged connecting rods, a dual exhaust, and a few other internals designed to accommodate the increase in turbo boost from roughly 10 psi peak to 15.<ul><li><a href="http://en.wikipedia.org/wiki/Audi_tt">http://en.wikipedia.org/wiki/Audi_tt</a</li></ul>
shlt after 6 years of having one, i found out, only have 1 turbo ....
but seriosly,
Bruno, you forgot quattro, & better stereo
also bigger tires as option, no 18" for 180hp.
as far as i remember. (as of 2003)
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
ayap
09-19-2015 07:56 PM
mrprism133
09-07-2015 07:22 PM
Audi R8 2009 Audi R8 3k miles!
One_Murphy
09-04-2015 06:40 AM
