For those interested here is a brief pictorial with some explanations on the Second Intercooler ...
Mod for the B6 A4 1.8T. All parts are OEM from the 190Hp version of this car available only in Europe. Everything is a direct bolt on with no modifications required.
First remove both inner fender wheel wells (plastic liners) on each side. On the left side of the car you will see the W/W reservoir.
<img src="http://pictureposter.audiworld.com/46874/2ndic13.jpg">
Remove the three screws on both sides. This is done to remove the entire front bumper cover assembly.
<img src="http://pictureposter.audiworld.com/46874/2ndic14.jpg">
Remove both black plastic grills around the fog lights. Unscrew on both sides a small black screw, see top left. Not shown but on the opposite side (top right) of the black screw is a larger screw, one on each side that also as to be removed. Before pulling off the bumper cover you will have to disconnect the hoses for the headlight washers (quick release) and the electrical plug for the horns and fog lights, also a quick release. These are located near the W/W reservoir.
<img src="http://pictureposter.audiworld.com/46874/2ndic15.jpg">
Second intercooler.
<img src="http://pictureposter.audiworld.com/46874/2ndic10.jpg">
OEM Hoses that came with the second Intercooler kit. Also the new bracket to relocate the secondary air pump.
<img src="http://pictureposter.audiworld.com/46874/2ndic4.jpg">
Secondary Air Pump (SAP) in its original location in the engine bay.
<img src="http://pictureposter.audiworld.com/46874/2ndic17.jpg">
SAP in its original location, close up.
<img src="http://pictureposter.audiworld.com/46874/2ndic9.jpg">
SAP with the original bracket removed from the motor and the new bracket waiting to replace it.
<img src="http://pictureposter.audiworld.com/46874/2ndic11.jpg">
Original OEM hoses with expansion chamber and BPV removed.
<img src="http://pictureposter.audiworld.com/46874/2ndic7.jpg">
OEM BPV replaced by a FORGE BPV.
<img src="http://pictureposter.audiworld.com/46874/2ndic12.jpg">
Second intercooler installed (close up).
<img src="http://pictureposter.audiworld.com/46874/2ndic6.jpg">
I/C installed different view. Notice the hole in the top right portion of the rubber shroud. This is the hole where the water mister jet will be located. This year I will try to add a second jet per I/C to augment the cooling.
<img src="http://pictureposter.audiworld.com/46874/2ndic5.jpg">
Another view of the I/C.
<img src="http://pictureposter.audiworld.com/46874/2ndic3.jpg">
SAP's new bracket and new location within the engine bay.
<img src="http://pictureposter.audiworld.com/46874/2ndic1.jpg">
New bracket location, other view showing it in its relationship to other components, notice the APR snub mount and the second I/C.
<img src="http://pictureposter.audiworld.com/46874/2ndic8.jpg">
SAP installed in its new location. Notice the second I/C in the top right portion of the picture.
<img src="http://pictureposter.audiworld.com/46874/2ndic2.jpg">
After the installation is completed just re-assemble the front bumper cover in place and secure it, then re-connect the electricity to the horns and fogs. Don't forget the head light washer system too.
Second intercooler.
You would have to call GreedSpeed in California to get the latest price if the kit is still...
Available. Originally it was $650.00 US.
Touge.ca
Canadian Discussion
10-18-2015 07:18 AM
Touge.ca
Canadian Discussion
09-26-2015 11:30 AM
