q7 intermittent starting problem HELP
hi i have a 2008 q7 3.o TDI which has a intermittent starting problem
on turning the key the engine cranks for about 4-5 seconds then stops you then have to release the key and start again it does not do this every time and can be hot or cold engine some times takes 5-6 goes i have scanned with VCDS and no faults showing
this fault has only appeared since i have replaced EGR cooler (which was not a nice job) i have checked all connections and know run out of ideas any help would be appreciated
NR04
08-28-2007 12:27 PM
